b16 slight miss in ignition?
my motor seems to have a slight miss you can feel it especially at around 3000rpm to around 5000rpm. You can also feel a vibration to go along. Cant figure it out new plugs and wires, replaced the distributor, cap , and rotor. Also installed new fuel filter.
Thought the vibration was first in driveline like cv axles but replaced both and still vibrates. Replaced all tie rods and steering rack. Only thing i haven't replaced it the clutch, thinking i put a hot spot on the flywheel or pressure plate since this all started happening when i was going 45mph and downshifted into 2nd gear and gunned it. When i did felt like the wheels were kinda hopping then had this wierd vibration since. Also thinking of changing timing belt to see if that helps even though timing is dead on.
someone please post your ideas and i'll try to see if they work and let you know...
http://hometown.aol.com/hahaga....html
Brent1
23
12-31-2005 03:01 PM
ApolloSpeed
14
08-19-2005 09:12 AM
