auto-manual parking sensor?
Old 11-18-2010, 08:44 AM
joppa_smoot's Avatar
Default auto-manual parking sensor?
ok, i jus got my ls in my ef sedan...we got it fired up last night, but i cant start it with the key or roll the ignition back to take the key out. It was an auto but we converted it. My people said something bout a "parking sensor" or something, PLEASE SOMEONE ELABORATE!!! I gotta get it running right asap!!!
Old 11-18-2010, 09:15 AM
Default Re: auto-manual parking sensor?
come on guys...i really need ur help H/T...lmk if i gotta give more details or somethin
Old 11-18-2010, 09:35 AM
rwdsohcef's Avatar
The problem you are describing sounds like a cable that goes from the old auto shifter the the key switch that will not release the key when it is not in park. I am not entirly sure the ef auto had that. If it does it is a case of pulling or pushing the cable to make the ignition relax and let the key out. As far as not starting, same ecu? at least you need to ground the ecu wire that is neutral safety switch wire.
There are so many reasons like simply a stuck key, how to u do the wiring? ECU swap? what else did you do?
So you got the key to turn it on then jumped the starter I assume. If so you are close, check on the things I have listed. I am going on a service call, wont be home for hours.
Old 11-18-2010, 09:47 AM
thanks for the help, i know its not the ecu because thats a PR4 so im good there...i'll check on the neutral safety switch wire though...as for the key, if you put the key in and roll it forward the only way u can get it out is if you disconnect the battery...and yes, we did the ol "starter ground plug to the positvie terminal" to get it to start...where would that cable be?
Old 11-18-2010, 09:52 AM
rwdsohcef's Avatar
Then there is an electric cylinoid on the ignition mechanical switch part you need to remove, take the column plastic off and have a buddy hook and unhook the battery and remove and discard the clicking part. The only reason I asked about the ecu is because if it is a auto ecu then you have to ground the neutral saftely switch wire to make the starter work with the key. Hope this helps gotta go.
cow1787
08-26-2023 09:08 PM
99EK_Hatch
10-15-2014 08:16 PM
medrano51
Honda Civic (2001 - 2005)
20
02-22-2010 04:08 PM
jwaked
03-16-2006 03:50 PM
jwaked
03-16-2006 03:49 PM
Quick Reply: auto-manual parking sensor?
