another solid cel thread
Old Jul 26, 2008 | 10:50 AM
nitronaught6969's Avatar
Default another solid cel thread
ok so i did a wire tuck and turbo install at the same time on my b16 crx, and i had the evap and iat plugs switched so i burned up q31 resistor in my p72. switched the plugs, got a p28 ecu. still throws a solid cel with or without the srs jumped. the engine runs perfectly fine on the base map. is my second ecu bad? wiring issues?
Old Jul 28, 2008 | 11:46 AM
Default Re: another solid cel thread (nitronaught6969)
btw, all connections soldered and electrical taped
bump
Old Jul 28, 2008 | 01:13 PM
sanimalp's Avatar
$cat /dev/urandom
sounds like whatever is wrong with your wiring is shorting your ECU. You should go through your wiring before plugging in another ecu.
on the p28, since it already might be toast, you might as well try cutting j12 to restore the original factory ecu to see if it was just a bad chipping job, if it is chipped at all. if its not chipped, the ecu or the wiring might be bad..
Modified by sanimalp at 1:43 PM 7/31/2008
Old Jul 31, 2008 | 10:25 AM
Default Re: another solid cel thread (sanimalp)
yeas both ecus are chipped by different companies, so im pretty sure its a wiring issue, i just dont know how to find it.
sanimalp i sent you pm
ceearexx
Engine Management and Tuning
Jun 10, 2013 11:09 AM
TimiK
Dec 3, 2012 09:31 AM
spoonhatchblack
Nov 4, 2004 10:12 AM
streetlvlhatch
Dec 26, 2003 12:59 PM
simonc
Dec 23, 2002 12:40 AM
