93 Integra ecu in 89 hatch si
![Default](https://honda-tech.com/forums/images/icons/icon1.gif)
Im doing a ls swap in my 89 hatchback si. The ecu i currently have is from my 93 DA which used to be a automatic which i swapped to a manual, and all i did was make it read in park for the car. Will this ecu just plug in (once i repin the obd1 plugs on the 89 harness) and work fine?
yea im wiring in the odb1 plugs on the obd0 harness, using the info from :
https://honda-tech.com/forums/showth...d0+obd1+wiring
im just making sure once that is done i wont have an issue from it being a automatic ecu, cause when u do a auto to manual conversion u have to make it think its in park so it wont give u issues. So im trying to clarify that once that is done (the link above) itll work
![Happy](https://honda-tech.com/forums/images/smilies/emsmile.gif)
You could have bought the harness for like $40 shipped and not had to hack up the wiring at the ecu on the hatch. You never know when a different motor may get swapped into it.
