91 Hatch w/B16A Dead. Cylinder #2 is dead, everything electrical is working?
Old 08-16-2012, 09:33 AM
  #26
MzdaFrk's Avatar
Default Re: 91 Hatch w/B16A Dead. Cylinder #2 is dead, everything electrical is working?
Morning update, i took the car out last night to see if the problem would come back, it did. but it was different then before. When I drove the car it would run fine then miss for a second then smooth back out. made it back home and it started to stumble and die. then it smoothed back out. I'm very puzzled,
when it starts to miss it smokes like crazy, smells like gas really bad. I don't have all my tools with me, so i haven't done the noid light test, i have those at home. I don't leave for a few days so i am going to keep testing. If I haven't figured it out by Monday ilk just pull the injector clip and plug wire and drive it back home on 3 cylinders. i would much rather find the problem though.
Old 08-16-2012, 09:36 AM
  #27
MzdaFrk's Avatar
i have not tried another ecu, i have a p30 at home for my OBD1 conversion, i could pick up a new distributor for an OBD1 car and try that?
Old 08-18-2012, 10:04 PM
  #28
netfreak's Avatar
Just throwing an idea out there, try replacing the coil and igniter in the distributor.
Old 08-18-2012, 10:45 PM
  #29
Swap'DShuttle's Avatar
I think you're on to something with something ignition related getting hot and not working right. Our dizzys are very susceptible to heat, and like netfreak said, try a diff coil and ignitor. Don't just replace though, try a good working one first. Throwing money at a car is never the answer.
Also don't remember if you said it was obd-0 or Obd-1 but if you can I'd try a diff dizzy that you know works.
Old 08-18-2012, 11:55 PM
  #30
tonylovesjdmEF9's Avatar
it sounds like your dizzy is takinga dump why because it seems to be like it gets hot and then it just starts to miss swap dizzys out and try it out you should pull the 2 spark plug cable when its missing and see if its working
Old 08-19-2012, 01:26 AM
  #31
JuicedUpRice's Avatar
This.then update.
Old 08-20-2012, 03:13 PM
  #32
MzdaFrk's Avatar
will do, i need to find a working one, anybody in Portland area have one i can try?
Old 08-20-2012, 03:16 PM
  #33
MzdaFrk's Avatar
i just came out to the car and it fired right up, no miss. I'm letting it warm up and then i will take it out. so now for a newbie question. if i want to find a distributor for an obd0 b series, should i look at a DA integra?
Old 08-20-2012, 04:05 PM
  #34
crvtectim's Avatar
Nah, they're non-vtec. You need a vtec distributor to work with your obd0 pr3 or pwo.
Old 08-21-2012, 01:00 AM
  #35
MzdaFrk's Avatar
so what car should i be sourcing a distributor from?
Old 08-21-2012, 05:20 AM
  #36
dc5itracer's Avatar
Another obd0 b16
Old 08-21-2012, 01:14 PM
  #37
crvtectim's Avatar
http://www.ebay.com/sch/i.html?_saca...ibutor&_sop=15
Old 08-21-2012, 09:51 PM
  #38
MzdaFrk's Avatar
i went to the local parts store and got a ignition coil, distributor cap and rotor put those in, and the problem hasn't came back all day, I'm leaving back to Cali in a few hours we shall see if the problem comes back. i put a hundred miles on it and nothing so I'm crossing my fingers. I'll let you all know what the status is.
Old 08-21-2012, 10:17 PM
  #39
GOODLUCK would like to know what happend??
Old 06-15-2013, 10:37 AM
  #40
MzdaFrk's Avatar
sorry, i forgot to give an update. the coil fixed the problem.
Old 06-15-2013, 10:44 AM
  #41
MzdaFrk's Avatar
now im having a new issue.
I just stripped the car down and replaced a bunch of parts. put it all back together and my injector #4 is staying flooding the cylinder.
I pulled the engine, tranny, suspension, wiring, exhaust, brakes, and ecu. I installed all new gaskets on the engine, checked the clutch, new axles, new brakes, obd1 conversion, header, intake mani, distributor, ecu, cat back, and some dress up parts. when I reinstalled everything, it would crank and not fire, so I started tracking down issues, found that the injector was staying open on cylinder 4. I converted it back to obd0 and it fired up. stummped, so I put it back to obd1 and tried a different ecu, same problem. I replaced the distributor with a brand new obd1 td44 and it fired up, but the injector is still staying open. I checked continuity to the ecu and the wiring is good, so now im checking grounds. I find it weird that it runs as obd0, but with the conversion Im having an issue?
Has anybody else dealt with that?
Old 06-15-2013, 07:49 PM
  #42
MzdaFrk's Avatar
ok, made a new sunharness today and bypassed all existing wiring. that fixed the problem with the injector. now I'm throwing code 41, which is heated o2. the RyWire ecu conversion uses
position b1 to go to the injector power on the obd0 harness. and the subharness supplies the wires to the heated o2 sensor. so if the factory obd1 uses b1 to supply pet to the injectors and o2, could that be the problem?
Andycuso
02-12-2013 08:52 AM
RedSuns86
10-17-2009 12:38 PM
SmackerS
02-23-2008 04:18 AM
Bob_760
10
10-11-2006 12:20 PM
SHG_Beans
04-26-2006 11:44 AM
Quick Reply: 91 Hatch w/B16A Dead. Cylinder #2 is dead, everything electrical is working?
