91 CRX Si Rebuild
#26
Re: 91 CRX Si Rebuild
Looks amazing, really coming together nicely! Did you have any issues taking off the door handles? Also how did you get your door moldings off without breaking the clips?
#27
The wheels i have had for like 15 years...i will guess Rota but its been so long i dont believe i bought spoon's. I did not have any issues taking the door handles off, you just have to be very careful to not mess up the paint. In this case putting them on is the tedious task The door moldings i took off so long ago i do not recall if i broke any. Fenders, rear quarter and door center molding on both sides are brand new oem. That also goes for the strip at the bottom of the window, the one around the window on the inside and then the top of the door where it meets the car. The door sashes are also brand new oem.
#28
Are those pieces still available through the dealer or did you purchase them long ago and just keep them hoarded?
#29
I have connections from when I worked for Honda for a decade but still have not been able to get new factory EF parts for the last 5 years. It looks like someone bought out all of the OEM parts then is selling them for a ton more online.
#30
yay new rear hatch struts
css block back from jeff @ cnc werx and boy does she look ******* sexy.
little headlight
i bought a "universal carpet" and well i dont like how my install went...im looking for other carpet options. i do not have the original to make a template either.
if memory serves this is the horn and 2 plugs for the washer motor? meh ill find out and probably just trash all these
these 2...one is for the bumper light...the other im not 100% sure. need to do some research.
#31
Looking good and waiting for further updates. i am currently building my EF that i just bought as well. And I'm "Skunk2'd Out" as well LOL
#32
haha thank linkdeezie. i will probably continue to be skunk2'd out i think. Driver side should be good for now. each light was loomed with 1/4" PET then all slid into a 1" PET loom.
#34
Stock interiors passenger molded carpet installed. sort of a pain without having the original carpet BUT came out pretty good i fell
carpet will be sucked up a little once i finalize if i want the odyssey battery to reside in the cargo compartment.
#35
Passenger wire tuck completed for now.
installed the rear quarter windows
#36
what are you trying to pull here?
you cant say installed the rear quarter windows and show us a picture of one of them not installed ^_-
crx is coming along great man keep it up
#37
Haha not sure why i uploaded that video...got some more engine parts incoming this week. i think for now i will stop with the body. focus on getting the motor built and put into the car to give her roughly 500 miles of a engine/clutch break in before i piece together a turbo kit
#38
Just Arrived:
Moroso Oil Pan
ACL STD Bearings / Thrustwashers
Ordered:
Synchrotech Carbon Rebuild Kit
MFactory LSD
Skunk 2 Composite Fuel Rail
Skunk 2 LMA's
Thermal Intake & Throttlebody gaskets
Skunk 2 Cam Gears
CRX rear triangle pieces
Need:
Oil Pump
Motormounts
Headgasket
IAT
MAP
Hondata
JBTuned fuel lines
The need is what i think i need to to get her into the car so i can then start my wiring harness. going to do it similar styled to how i did the wire tuck. Ill have some more pictures of the tranny stuff soon as it arrives.
Moroso Oil Pan
Ordered:
MFactory LSD
Skunk 2 LMA's
Skunk 2 Cam Gears
Need:
Oil Pump
Motormounts
Headgasket
IAT
MAP
Hondata
JBTuned fuel lines
#40
Thanks Lank...i had a grown man fan boy moment when i saw it lol.
#41
Great job with the build by the way! The car is looking awesome, I can't wait to see where you take it. That wiring is inspiring (ha, I made a rhyme), it seriously looks super well done!
#42
Just to clarify if you were calling me The Acid Beaver....i am not. I have had conversations with him way back in the mid 2000's on thezcr when it existed or was even thezcresource.
#43
Synchrotech / MFactory parts are in.
Carbon Rebuild Kit
MFactory Helical LSD
I would also like to state that i ordered 1 diff bearing accidently BUT within 5 minutes of my purchase i received an email saying i only ordered one and they are typically ordered in pairs. I agreed and it was my error as i didnt look over the order. Super simple fix and greatly appreciated the email. Synchrotech customer service has 2 thumbs up!
Carbon Rebuild Kit
#44
subbed to follow along, just picked up a pretty much completely stripped down 91 Si and will need this thread for help putting her back together haha.. rebuild looks great so far!! good work.
#45
yay!
Whoohoo more parts
Synchrotech carbon rebuild kit with mfactory LSD
in with the new
out with the old
Whoohoo more parts
in with the new
out with the old
#48
Surprisingly it is, there is quite a few videos on youtube discussing/showing it. That being said just remove things as as you do keep them in order then its quite simple. Having access to a press and puller made some tasks easy too. Ordered an OEM headgasket and oil pump of which should be here thursday. I dont want to assemble the motor till it can all go together. a JBtuned fuel tuck kit is in order too. On the fuel topic im going to try and drain my tank and see whats up or just end up dropping it to see if i can flush it. Its been sitting for ehhh a long time.
#49
OEM GSR Oil Pumo & Headgasket
Hasport Cable Tranny Mount Kit
#50
Well my fuel fuel and brand new gas tank arrived. I was about to order more parts and damn Hurricane Michael came. He caused some solid havoc and long story short i had to move stuff to a storage unit so im on hold for a bit now :/
