injector question
Old 03-14-2017, 04:40 PM
famdakam's Avatar
Default injector question
can i use the injectors from a 94 z6.. on a obd0 zc... the plugs are different i was wondering if i can cut and switch
Old 03-15-2017, 06:04 AM
#1 Super Guy
94eg!'s Avatar
Default Re: injector question
I believe you would have to remove your resistor box...and plug a jumper harness in its place.
Old 03-15-2017, 10:42 AM
famdakam's Avatar
Thanks for the reply im just going to get some obd0 injectors to make it eaiser... or are the obd1 better?
Old 03-15-2017, 02:25 PM
#1 Super Guy
94eg!'s Avatar
No idea. I believe the only difference is weather or not you need the resistor box. BTW: You can still find brand new OEM CRX injectors (made by Keihin) on e-bay (or other places) in a Bosch box. I think the part# is 4920565, but please verify 1st.
Old 03-15-2017, 02:40 PM
famdakam's Avatar
Ended up using ones i already had they were on my b7.. and one has a crack on the plastic part where the gas comes out..it runs fine..
Old 03-15-2017, 03:04 PM
bbarbulo's Avatar
runs fine is not the same as runs right. d15b7 is obd1 so you still need to remove the resistor box. saturated injectors are considered better than peak/hold injectors, so nothing wrong with using OBD1 injectors. just the resistor box has to go.
Old 03-15-2017, 03:06 PM
famdakam's Avatar
Ok then not from the b7 because obd1 has different plugs... i had them laying around and they worked... i dont want to have to chop up the harness.. yet.
Randysi
04-04-2012 10:17 AM
makoto
04-11-2007 10:38 AM
pinecone
04-25-2006 06:41 AM
killa rex
01-25-2006 02:54 AM
Quick Reply: injector question
