89 STD hb won't start need help troubleshooting
89 STD HB everything is stock
so far ive checked:
no ecu codes
dist. timing is good
dist., wires, and plugs good
fuses in engine bay good
car has been sitting for a few months and supposedly did crank a while ago but it did not crank after trying to jump start and letting it charge a few minutes but does not crank at all now. I think it could be fuel related but im not sure where I should check to narrow it down'
so far ive checked:
no ecu codes
Re: 89 STD hb won't start need help troubleshooting (reese)
so it turns over and wont start? then ya it's more then likly your fuel system. Try replacing your fuel filter, if that dosent work then add some of that Anti Water fuel additive and let it sit a while because water coiuld have got into the system
Re: 89 STD hb won't start need help troubleshooting (Jared)
it used to crank from what the owner says but now it does not crank at all after trying to jump start and letting the battery charge a few minutes
Ace0246
13
09-03-2005 12:09 AM
drifto808
12-03-2003 04:15 PM
