89 CRX HF B18B1 Swap
I found a B18B1 longblock for sale for $100 USD and it needs valve stem seals fixed on it. All I need to know is if it's a good idea to buy it and fix them for my 89 CRX HF B-series swap that I'm working on. Wether or not it would be a good investment. Thank you in advance!
EDIT: valve stem seals **replaced** on it.
EDIT 2: I ended up buying a B16A gen 2 for $650, complete long block. I just bought an A1 transmission as well with the 90-93 axles and half-shaft for $150. So, I'm getting it going and buying mounts and shift linkage in a week or two. Then all I need is the ecu (PR3, PW0, or P30, right?), running VTEC wires, and getting 4th Generation EX, DX, or Si knuckles/hubs. That's all I can think of that I'll need, to do the swap considering everything is on the motor and tranny. I would appreciate if I could get confirmation.
Re: 89 CRX HF B18B1 Swap
muellersfan said go for it ^_-
100 sounds like someone is just running out of room in there garage
go for it thats a great price
but yes your swap will need more and more parts of course
but if you can save a little here and there why not right
