88-91 prelude fog lights on an EF .........(almost JDM)
#26
Re: 88-91 prelude fog lights on an EF .........(almost JDM) (jdmpnoy89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmpnoy89 »</TD></TR><TR><TD CLASS="quote">
apc corners, custom bumper lens
mounting them was a pain, lots of test fitting and cutting
Thanks...man...I'll look into that...I saw a 88-89 STD that had amber lenses i the bumper...I just don't know if they are the same size:
#27
Re: 88-91 prelude fog lights on an EF .........(almost JDM) (GreenBean)
how this thread still alive??haha well i too have been looking for a set to bad that they are ALL 40 dollars a pair now..
#28
Re: 88-91 prelude fog lights on an EF .........(almost JDM) (La EF-8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by La EF-8 »</TD></TR><TR><TD CLASS="quote">Looks ok man</TD></TR></TABLE>
ehh
ehh
#29
Please someone help...
AFTER YOU INSTALL THE FOG LIGHTS HOW DO YOU HOOK THEM UP SO THEY WILL WORK WITH THE OTHER LIGHTS IN THE CAR?ALSO ONCE YOU HOOK THEM UP HOW DO YOU TURN THEM ON FROM INSIDE THE CAR LIKE YOU WOULD FOR YOUR OTHER LIGHTS?
#30
EFB055
Best way would be to ground them close to the front of the car, and source power from the accessory slots in your under dash fuse box. One of the accessory prongs will power up only when you switch your lights on. Use a test light to work out which is which.
Or run an on/off switch and source power from the constant power source in your accessory panel in your fuse box.
#31
UndergroundTrev
07-24-2016 07:09 PM
