86 CRX??? Can I do anything with this car???
New User
Big time newbie here.... Can i modify anything on this car, and can someone throw me some links so i can learn more please?
New User
Re: 86 CRX??? Can I do anything with this car??? (GraftedAngelWings)
BTW, its an 86 Si with pgm-fi engine, 5 speed man. 12vavle engine (never saw that before...) any help would be greatly appreciated.
New User
If you don't want to do a swap( possible with HASPORT mount kit ), you can always use an intake tube, find A header( pacesetter I know has one, but check around for other brands ), and an exhaust. Any number of engine mods can be performed if you want to tear that motor down and rebuild, and I remeber stumbling across a bolt on turbo kit online somewhere. It was pretty slick, but you had to give up your AC( someone on this board may know the adress of the page, I lost it unfortunately).
Being that it is an Si, you could drop in a 86-87 Teg motor. Fits right in and the wiring matches up as well. But if you don't want to do any swapping, then go with the bolt-ons like the other dude suggested. HTH.
cyber13
cyber13
The turbo kit was http://www.turborex.com, but it's gone now. The kit used the exhaust manifold from the carbureted Civic/CRX and mounted a turbo where the close coupled cat was. I did save the parts list here: http://www.geocities.com/internethit...rboparts.html, if you want to find the parts yourself.
Other links: http://www.opmmotorsports.com/ http://nav.webring.yahoo.com/hub?ring=3gcivic&list http://www.centerforce.com/ http://www.ground-control.com/ http://www.knfilters.com/ http://www.dcsports.com/ http://www.tokicogasshocks.com/ http://www.kyb.com/ http://www.gude.com/ http://www.roadracegear.com/products.html http://www.dobiperformance.com/open.html http://www.asylumms.com http://www.aempower.com
I believe all these companies make stuff for the '84-'87s.
illogic65
08-29-2004 02:17 PM
