6-7 rpm feels laggy on 1st n 2nd gear
do anyone knows what is wrong when i hit first and second gear all the way to 6-7rpm and it feels kinda laggy any comments is helpful It's for a d16z6
Re: 6-7 rpm feels laggy on 1st n 2nd gear (CimorelliCRX)
i cant tell when vtec is kiking it or not. it feel quick but alittle laggy so i adjust the regulator to 38 psi. i have i/h/e. i thought i needed alittle more fuel or sumthing. no codes also.
Re: 6-7 rpm feels laggy on 1st n 2nd gear (Ignitecivic)
waht is your setup? full d16z6 engine running obd1 or is it off a obd 0 ecu? give us more info. prolly your VTEC not kicking in or you have the wrong ECU and not enough fuel for the VTEC range
Re: 6-7 rpm feels laggy on 1st n 2nd gear (89 CRX SI)
its the obd 1. with i/h/e, regulator and pressure gauge. i took out my vtec controller. and no codes are given. the only thing i was thinking was less fuel for the vtec range. right now im idle at 38 psi for fuel.
mmm yeah i think your leaning out in the high rpm vtec range. Do you have a Air fuel gauge? If not get one. they are like 25 bucks and well worth it. they can further diagnose this problem.
aight then guys. thanks for the help. yeah i have a air/fuel gauge. imma test it out again. the gauge is pretty crazy. it always jump back n forth. and lean at idle
New User
Just wondering how hot and humid, has the weather been in your area lately... hehehe
Also, try driving it at night or when it has cooled down... See how it acts, if you have not done so allready...
hushypushy
06-20-2008 11:46 PM
