450cc injectors in a stock crx?
Old 03-26-2009, 08:12 PM
ddubtoille's Avatar
Default 450cc injectors in a stock crx?
i have a D15 CRX DX with just a cat back exhaust and CAI and i was wondering would i get anything out of putting 450cc injectors off a 1st gen turbo eclips in my car? Also anyone know what size the stock injectors are?
Thanks
Old 03-26-2009, 08:17 PM
texaszcrx's Avatar
Default Re: 450cc injectors in a stock crx?
no definately not something you want to do. first of all your car is dpfi and you only need to upgrade injectors if you have forced induction or a built all motor setup. you should invest any thing into that engine. just save for a swap or do a mini-me head swap would be a good place to start.
Old 03-26-2009, 08:33 PM
ddubtoille's Avatar
i thought you couldnt do a mini me from d15 to the d16vtec? i remember one guy trying to but he was having alot of trouble
Old 03-26-2009, 08:54 PM
ddubtoille's Avatar
nevermind i found some d15 to d16 mini me swap things but the only ones i could find is a d15b7 and i have a d15b2 any difference?
Old 03-26-2009, 09:09 PM
93formula's Avatar
nope same procedure, but dont put those 450s in waste of money for your setup unless your boostin.
Old 03-26-2009, 10:23 PM
Pirate General...YARRRR
Ass$nyper's Avatar
Honestly, don't do this.
Old 03-26-2009, 10:54 PM
hai_tech's Avatar
juss get swap
Old 03-26-2009, 11:46 PM
Arthas's Avatar
how much would 450cc injectors off a 1st gen turbo eclips go for? and would they really be good for a 90 civic hatchback, sohc zc (non vtec) with a turbo or should i go for 550's??
Old 03-27-2009, 06:52 AM
aaronhume's Avatar
lol... they are good injectors if you are going to a turbo setup, so by all means, boost up. otherwise you will get crappy performance and waste a lot of gas by just adding these.
Old 03-27-2009, 07:23 AM
ddubtoille's Avatar
well i had plans to turbo it so i had bought these a few months ago for 30 bucks and now they are just sitting around cause i have no money for a while to continue with the turbo and i was just wondering what would happen if i had just put them in
Old 03-27-2009, 07:43 AM
shaggyeg6si's Avatar
You can add them and get decent performance from them but you have to either tune, or swap to OBD1 and tune.
Old 03-27-2009, 07:45 AM
Keyboard Humorist
4drEF's Avatar
Originally Posted by ddubtoille
... and i was just wondering what would happen if i had just put them in
Stock injectors are what 210/240? - something like that.
Your car would run stupid rich.
The fuel maps are for injectors 1/2 their size.
Old 03-27-2009, 08:08 AM
Without a tune, you will not idle properly at all. It'll idle at like 2000 RPMS or something rediculous like that. Also, if you do decide to put them in and tune, you need to make grommets for them to sit into on the factory intake manifold. The case on the injector is slightly larger than that of a honda injector. Check the 92-2000 Civic FAQ for more info.
Driftologist
08-27-2013 02:54 AM
driftam1
04-27-2008 08:56 PM
benihana881
06-14-2006 09:26 AM
dominate9
09-30-2003 05:52 PM
Quick Reply: 450cc injectors in a stock crx?
