1st Gen B16 valve cover bolt delima!!! NEED HELP!
So while changing my valve cover gasket I managed to break one of those 4 double threaded bolts that holds the valve cover down in the middle under the spark plug wire cover... I need help. I cannot seem to find a new bolt. The honda dealer can't even help me. I have tried getting the bolt off of the B16 in the Del sol but it was too long. Does anyone know where I would be able to get one of these bolts?
Re: 1st Gen B16 valve cover bolt delima!!! NEED HELP!
Thank you Captain Obvious, I couldn't figure out how to read the Wikipedia page.
You must have the only JDM engine in the states. No way someone would sell or part one on craigslist. No way one might end up in a salvage yard.
I just thought of something, try the JDM engine importers. Maybe one of them will have it or can get it.
or maybe actually invest in a torque wrench so your DA doesnt shear off valve cover bolts, because your trying to go BEAST on it.
Epic Fail sir
Epic Fail sir
Crazy Honda Guy
The valve cover bolts are one in the same! Both jdm and usdm, both 1st and 2nd gen, the bolts are the same, it is the same engine
same thing happened to me. i called a dealership in Japan and they had them in stock. So i had my boy Brian send them overnight so i could have the car finished in time for the big race
the bolts werent the same the one for the 2nd gen is longer. I found a part number online and the dealer happened to have 2 in stock the whole time. Definitely nabbed both of those bastards. Thanks for all your guys help
Crazy Honda Guy
I HAVE both a 1st and 2nd gen B16 here. I have swapped valve covers before, no issues. They are the SAME head, and mount the SAME way!
well I am just telling you on what I got from the dealer man excuse me to doubt your knowledge and ability to own every type of motor Honda makes
Crazy Honda Guy
All b16's use the same valve valve cover bolts from gen to gen, but do keep in mind, that the actual mounting of the cover does have a couple different part numbers, as to where each bolt is located. If i recall, the bolts on the ends, are different lengths than the ones in the middle. The parts guy who helped you, most likely ordered the wrong part number...very simple!
Part # 20 in the 1st pic, is different from that of part #24 in the 2nd....yet all b16 and B18C engines use the same two parts
i know that and I needed #20 and the one out of a del sol did not work on the one out of my crx. So I dont know what to tell you man. The bolt was too long to work for me and I managed to find the one I needed.
because you got the wrong one!!!!!!!!!!!!!!!!!!!
dont know how else to dumb it down for you dude.
he is saying all the VC bolts are the same for the b16 and b18c
I like the tuna here
Nice. I bet a couple of JDM valve cover bolts will pull a premium two weeks before Race Wars!
