[FAQ] Differences in CRX's.
Old 10-10-2005, 10:57 AM
  #26
InMyProject's Avatar
Default Re: Differences in CRX's. (rice_classic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice_classic &raquo;</TD></TR><TR><TD CLASS="quote">Let's test this knowledge here!
Will 88 si doors fit well on a 90-91 body?
88's will go on a 90 body. BUT 90-91 doors will NOT go onto an 88 body, without modification.
Old 05-10-2006, 09:05 AM
  #27
junior40er's Avatar
Default Re: Differences in CRX's. (JMod)
wow so theres a lot of difference. Would any of you guys buy a 88-91 CRX? can they fit the JDM front end?
Old 06-01-2006, 10:18 AM
  #28
CRXBart's Avatar
Location: Land of the free, whoever told you that is your enemy
Default Re: (92integra_gs)
I have seen this stuff asked so many times before, here are all of the weights of second generation CRXes. All of this information is posted in the autos section of MSN.com I conglomerated all of the years together for you. Not 90-91 didn't have a weight change on any models. All other years, all models weight changed.
1988 CRX HF 1819lbs.
1988 CRX DX 1922lbs.
1988 CRX Si 2011lbs.
1989 CRX HF 1834lbs.
1989 CRX DX 2048lbs.
1989 CRX Si 2138lbs.
1990 CRX HF 1967lbs.
1990 CRX DX 2103lbs.
1990 CRX Si 2174lbs.
1991 CRX HF 1967lbs.
1991 CRX DX 2103lbs.
1991 CRX Si 2174lbs.
Old 06-01-2006, 10:23 AM
  #29
crxforum's Avatar
Default Re: (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">I have seen this stuff asked so many times before, here are all of the weights of second generation CRXes. All of this information is posted in the autos section of MSN.com I conglomerated all of the years together for you. Not 90-91 didn't have a weight change on any models. All other years, all models weight changed.
I added that to my post on the first page and credited you. Tyson pointed it out to me.
CRX Forum
Old 06-02-2006, 10:21 PM
  #30
CRXBart's Avatar
Default Re: (crxforum)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum &raquo;</TD></TR><TR><TD CLASS="quote">
CRX Forum</TD></TR></TABLE>
Coo thanks.
Old 06-15-2006, 06:52 PM
  #31
4dr93civic's Avatar
can u use hf or dx front bumper on a si?
Old 06-15-2006, 07:28 PM
  #32
white90crxhf's Avatar
i don't see why they would be mounted differently.
Old 06-15-2006, 08:31 PM
  #33
philkehn's Avatar
i think the 88-89 and the 90-91 bumpers are different so im not sure on that.. and when swapping into a dx dpfi to mpfi is only about 8 extra wires which i did successfully as an unexperienced electrician
Old 11-21-2006, 04:53 PM
  #34
Under Con. CrX's Avatar
Default Re: Differences in CRX's. (mrspeaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">No its not ..STD engine has 70hp..DX engine has 90hp..
The power difference has something to do with the restrictor plate..</TD></TR></TABLE>
actualy it has 92hp and the dx has a more aggresive cam and in order to get the cam to work properly you have to get the ecu so its not in the restrictor plate
Old 11-21-2006, 08:06 PM
  #35
TeamRedline89Hatch's Avatar
Default Re: Differences in CRX's. (Under Con. CrX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Under Con. CrX &raquo;</TD></TR><TR><TD CLASS="quote">
actualy it has 92hp and the dx has a more aggresive cam and in order to get the cam to work properly you have to get the ecu so its not in the restrictor plate </TD></TR></TABLE>
beat me to it
Old 11-21-2006, 08:18 PM
  #36
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs &raquo;</TD></TR><TR><TD CLASS="quote">i love 2nd gen crx... but that is my opinion!</TD></TR></TABLE>
Old 12-17-2006, 12:21 PM
  #37
turbocrixhf's Avatar
Default Re: (STREETWERKZ)
90 or 91 si crx all the way is the absolute best platform to mod. however if you were obsessed with weight then i would go with the hf. i would leave the dx alone if you could.i have a si and a hf and ill take the 90 91 si anyday over anyother crx chasis.
Old 06-22-2007, 06:51 AM
  #38
drummingpariah's Avatar
Default Re: (turbocrixhf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocrixhf &raquo;</TD></TR><TR><TD CLASS="quote">90 or 91 si crx all the way is the absolute best platform to mod. however if you were obsessed with weight then i would go with the hf. i would leave the dx alone if you could.i have a si and a hf and ill take the 90 91 si anyday over anyother crx chasis. </TD></TR></TABLE>
More precisely, if you were ONLY obsessed with weight, go with the HF. In order to beef it up enough to get any kind of decent handling/power out of it, you'll be bringing the weight right up to the DX level (the Si had the sunroof, which bumps its weight up above "necessary). I still have my '91 Si, and it's my favorite car I've eer owned (out of 23, so far). There are several options to "upgrade" but they're some of the most fun cars out there, right out of the box (or backyard, or friend's house, or garage, or wherever you drive it out of )
Old 06-22-2007, 11:36 AM
  #39
HBK
HBK's Avatar
thats not an opinion, thats a fact of life.
Old 06-22-2007, 11:38 AM
  #40
HBK
HBK's Avatar
Default Re: (HBK:CRX)
I've owned an 88 crx dx 5spd, a 91 crx auto dx, a 90 dx auto converted to 5sped, and a 91 crx si.
My fav? The 88 DX. That **** was light as hell. It was already converted to mpfi when I got it, and it had 90-91 si rear disc and suspension.
Well worth the work on a lighter DX, but my ideal CRX is no doubt a white 88 crx si
eat that thenick
Old 08-21-2007, 06:21 PM
  #41
bubba_crx's Avatar
Default Re: (HBK)
Can anyone tell me what makes the 90 dx heavier than the 91 hf...I have a 91 hf but found a 90 dx in better condition and was going to swap everything into that one.
Old 09-18-2009, 11:03 PM
  #42
akshn1's Avatar
Default Re: [FAQ] Differences in CRX's.
hey r the crx si and civic si under dash harness(the long one) the same?
Old 09-19-2009, 06:26 AM
  #43
DEIVIONCRX's Avatar
HF's had a smaller gas tank.
HF's had only one side mirror.
HF knuckles use a smaller outter CV stub. Same size as the 84-87 Cars.
HF's have a hollow cam, and 8valve motor.
HFs have lighter less complex bumper rebar's.
Hf's also had a better Coefecient of Drag(sp)
Old 01-12-2013, 02:18 PM
  #44
PsychoRex's Avatar
I need to know if a EF Hatch front bumper support will fit my 89 CRX?
Old 03-03-2013, 03:49 AM
  #45
lcg18952's Avatar
Default Re: Differences in CRX's. (ham)
Originally Posted by mrspeaker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">
std engine is the same as the dx, 16v d15b1/2 only with a 4speed
so just removing the plate step it up to 90?
Old 03-04-2013, 02:26 AM
  #46
skill178's Avatar
Originally Posted by P h i l
i thaugh only the 91 si had rear disc but i could be wrong
your correct, 88-90 are drum, 91 are disk.
the EX does NOT have disks and this is also CRX spec's only, EX is a civic.
Old 03-04-2013, 02:31 AM
  #47
skill178's Avatar
The Throttle bodies are the big difference, the top Butterfly, opens 1/2 way on the b1, Also the spacer plate, between the manifold and throttle body has a smaller diameter, on the b1. So basically there identical except the B1 let less air in.
your best bet for making any sort of power with d15b1/b2 is get a d16 mpfi intake and convert.
Old 07-10-2017, 11:11 AM
  #48
Slowpoke9's Avatar
Resurrecting the old thread.... did anyone figure out why the DX and Si models went up ~127lbs between 88 and 89, but the HF only went up 23lbs? Then the HF when up 133lbs for 1990?
Is it possible that the door reinforcement happened on the DX and Si in 1989 but only in 1990 on the HF? Anyone else know where that 127lbs would have come from for the Si?
Thanks.
Old 07-10-2017, 06:35 PM
  #49
Tyson's Avatar
Yes the door and seat belt nonsense didn't happen on the hfs in 89.
Bumper reinforcement differences too.
Old 07-16-2017, 07:58 PM
  #50
bheinen74's Avatar
Hf combination switch is also different (no rear wiper on the right stalk) also HF has thinner lighter sun visors, the steering column is lighter since it doesnt have tilt, the rear hatch has no window wiper motor, holow front stabilizer bar, lighter springs, etc etc etc....norear cargo tray or rear speakers or fold down divider..
:mR. PotAtO heaD:
14
12-05-2005 01:58 PM
The DX Rex
09-10-2005 05:32 PM
gutted-dx
01-10-2005 06:46 AM
project dc2
08-05-2003 05:57 PM
paRRRker
08-07-2002 07:40 AM
Quick Reply: [FAQ] Differences in CRX's.
