Rd1 lifted turbo build
#27
Re: Rd1 lifted turbo build
Is that the poly engine mount?
That looks like the cheapie $100 odd suspension rebuild kits you find on eBay, Amazon and other spots?
I'd be interested to hear your opinion on their quality and how they work once fitted, that upper control arm looks pretty decent, apparently the ball joints can be a bit dodgy though.
#28
1320 poly mounts.
the suspension kit feels junk got it for the ball joints and tie rods and to have as spare parts but think I'll return it and get adjustable control arms and better quality ball joints
#29
#31
Motor mounts made a huge difference. Wouldn't recommend on a daily driver cause it vibrates like crazy. But huge throttle response and handle difference
#32
Something is way off in the suspension.. when I getting the power it gets death wobbles like my jeep, scary. Hopefully balljoints and alignment will fix this.
My base tune I've been working on feels safe enough to make the 100 miles to tuner, I think. Rich but shouldn't break Ford fusion gauges photoshopped and changed in hondata
#33
https://youtu.be/e78fKgrH62I
needs alignment and tune. Getting a go autoworks log style manifold, cannot get rid of an exhaust leak. Only hitting 5lbs
#34
Headliner was destroyed so picked up some suede and fiber optics. $150 in total with about 450 stars.
#36
#38
Hey can you explain more on your shifter and did you use also a 2005 Honda civic Cluster? Im working on my RD1 aswell will be following your build as inspiration same here going turbo after smog
#39
I used a 05 civic skunk2 shifter cup, then put it on the shifter. It's not easy getting the ball into the cup. makes huge difference. I also added a 3.75" extension. Yes it's a 05 civic cluster. I'm having a nightmare of a time with most of my threads/head for turbo manifold are stripped. Might be going gsr head this week
#40
#41
found out that the threads on the head had been helicoiled for the exhaust manifold. Looks like I get to helicoil them again
#42
Can you describe the shake you were having in more detail?
I am on my third set of new axles, last two were from Rock Auto and the first came with the car but all have had the exact same shake under accel. Wondering if I need to try different brand axle or what.
#43
the shake I had I'm pretty sure was a combo of bad ball joints, alignment and axles. Almost forgot motor mounts. Mine were shot
#45
Few links to my parts list. Will be adding more
Rear camber kit
https://www.amazon.com/gp/aw/d/B079HH8N4S?psc=1&ref=yo_pop_mb_yo_pop_mb_pd_t2
Exhaust cut out
https://www.amazon.com/gp/aw/d/B01MXLXT0G?psc=1&ref=yo_pop_mb_yo_pop_mb_pd_t2
Tie rods
https://www.amazon.com/gp/aw/d/B000C59WDO?psc=1&ref=yo_pop_mb_yo_pop_mb_pd_t2
Faux suede... surprisingly good quality
https://www.amazon.com/gp/aw/d/B00O29SERQ?psc=1&ref=yo_pop_mb_yo_pop_mb_pd_t2
Fiber optic driver...
https://www.amazon.com/gp/aw/d/B073CSNQVS?psc=1&ref=yo_pop_mb_yo_pop_mb_pd_t2
Light bar...
https://www.amazon.com/gp/aw/d/B01MY1W7AO?psc=1&ref=yo_pop_mb_yo_pop_mb_pd_t2
Rear camber kit
Exhaust cut out
Tie rods
Light bar...
#47
I remember when I found out that I suck at tinting windows. I had a 1990 AWD Civic Wagon, that brownie-gold color, and thought it would look cool with dark windows but I was in college and didn't have money to pay someone to do it. Bought just enough supplies to get started and began with the rear window because I figured if I could do that one, I could do all of them. Well, I couldn't do that one. I got about halfway through, realized I was wasting my time, and that was that.
Forgive my ignorance, but what is it that you're making out of ABS plastic? It appears to be a gauge pod for pedestrians standing on the sidewalk next to your car, but that makes about as much sense as me trying to tint my own windows.
#48
#50
Skunk2 shifter cup
https://www.amazon.com/gp/aw/d/B008L0GQ1I?psc=1&ref=yo_pop_mb_yo_pop_mb_pd_t2
shifter extension
https://www.amazon.com/gp/aw/d/B00VRT23PI?psc=1&ref=yo_pop_mb_yo_pop_mb_pd_t2
