Honda CR-V & Element 2WD & 4WD Element & CR-V
Honda Diagnostic System (HDS) Software???
Old 03-17-2011, 02:23 PM
Odinthegod's Avatar
Icon2 Honda Diagnostic System (HDS) Software???
Hi.
I have a Honda CR-V 2002 model.
MY MIL light is on and the car wont start..
It starts.. Heh.. And runs for about 5 seconds. Then it stops..
I have this:
I need too do this:
But I need the program to do the diagnostic :-/
Can somone help me there? :-)
Old 03-18-2011, 11:46 AM
Odinthegod's Avatar
Default Re: Honda Diagnostic System (HDS) Software???
I've got the error code on my car (Honda CR-V 2002 Mod. AUT)
My problem is that the car starts but stops after three / four seconds.
MIL light is on.
When my mechanic is using the Scan Tool, he gets the code "P1298 unknown code"
My mechanic could not find the error code (NOT a Honda mechanic). He believes it is Crankshaft sensor. And that's a $900 job :-(
But after googling the code. I ended up in this Forum Thread ;-)
If I replace the ELD (P / N 38255-S5A-003) electronic load detector.).
(Does CR-V and Civic have the same error codes?)
Will the car work normally then? Or do I have other problems.
Old 03-20-2011, 05:26 PM
Havasu_Junkie's Avatar
From a tech standpoint, I think you have other problems. The ELD should not cause a no run situation, usually what will happen is the battery will continue to die and never charge. Or cause all sorts of different dash lights to be on, Battery light, SRS light, ABS, Engine etc...
But its a $30 part, and takes about 10 minutes to change. I can put up instructions if you need them. I would start with that though, you have the code, you have the problem, its sending faulty voltage to the PCM, so you don't need that.
taribest
Audio / Security / Video
10-28-2017 07:12 AM
slkslk2005
11-20-2011 04:22 PM
Banini
09-28-2010 08:42 AM
Quick Reply: Honda Diagnostic System (HDS) Software???
