Crank no start 00 honda crv
Hi i have a 00 honda crv that cranks no start i changed the distributor crank sensor new plugs and wires i have spark good fuel pressure and compression i spray start fluid and still wont start and i has a new main relay what else can it be thanks in advance
Re: Crank no start 00 honda crv
Timing is good spark is good i only have a crank no start issue after the engine is warmed up it wont start till the engine cools down the main relay is brand new alonge with the distributor and fuel pump and timing belt crank sensor is also new
Well, good spark, fuel, timing, ... sounds like it should start??
The engine warms up to operating temp and the engine won't start?
That sounds like an electronic part failing when it heats up????
Sorry can't help. Still learning about Honda. Just got an 2007 CRV.
No AC and poor power steering.
Please keep updating if you find a fix .. thanks
When you say you replaced the distributor, do you mean just the cap or do you mean the whole unit including all internals (i.e. coil, ignition module, rotor, etc...)? Ignition modules are notorious for failing in this condition (runs fine until engine is warmed up, then vehicle stalls and won't start). If you replaced the entire distributor unit with a non-honda one you probably got a cheap Chinese ignition module and those really don't work so well.
I am have similar issues after my 01 CRV warms up, if it a quick drive it will usually start right up but if you drive for a bit or have multiple stops it won't start unless its been sitting for awhile. It will crank but not fire up, I have switched out the distributor and also the main relay so far.
i hate dead threads. im having a similiar issue but it wont start at all now.
replaced cap, rotor, ign coil, ign control module, wires, plugs, fuel filter, fuel pump, checked the timing belt
compression 180,150,180,180
pulled off the fuel rail with injectors attached and they all spray just fine.
all plugs fire but the spark seems weak/wrong color
someone please help
someone please help
I have changed my distributor, starter,spark plugs, ignition leads, I have power to the starter, coil primary and secondary voltage good, new positive voltage terminal, resoldered the main relay, checked all the fuses ffs anyone have any other suggestions before I scrap this heap of **** 1995 Honda CRV
Anyone have any ideas? Mine still does it and now just sits in our driveway. Now I am also dealing with a parasitic draw from something and it is killing the battery.
I have a 2001 CRV, 239k miles, that will crank only if I put gas pedal all the way down to floor. It won't start otherwise. It will warm up for 3-4 minutes at 1500 RPMs and when it goes down below 900ish RPM it immediately stalls / dies. It will restart and run for maybe 1 minute and repeat. Has anyone noticed the throttle / gas pedal situation with theirs starting?
