Honda CR-V & Element 2WD & 4WD Element & CR-V
Bizzare issues after o2 sensor replacement
Old Apr 6, 2014 | 06:17 AM
luckydogie's Avatar
Default Bizzare issues after o2 sensor replacement
My son and I put in a new o2 sensor and window regulator yesterday.After we were done he went to drive it and 5 codes came up and he cant drive it because of the tranny codes. I had a hard time removing the plug on the front o2 sensor, but thats the only thing i touched under the car. Codes are p1298, p0135 p0141 p1753 p1768 no codes shown before we fixed it. Thinking broken or shorted wire but dont know where to look. Any help would be greatly appreciated. It,s a 2001 crv.
Old Apr 6, 2014 | 08:03 AM
tony_2018's Avatar
Fish Twig
Default Re: Bizzare issues after o2 sensor replacement
Universal o2 sensor? Double check your wiring and reset the ecu.
Old Apr 6, 2014 | 08:24 AM
luckydogie's Avatar
I used an OEM denso 234-4011 o2 sensor. My main concerns are the tranny codes that are making it undriveable, It worked fine and never any tranny codes before i changed o2 sensor. Are there any fuses for the solenoids on the tranny? Codes are torque converter clutch solenoid and clutch pressure control solenoid. p1753 & p1768
Old Apr 6, 2014 | 09:32 AM
luckydogie's Avatar
Just pulled all my fuses and found 1 bad one, problem solved, Thanks
sampson100
Dec 10, 2010 08:12 AM
anothersickhatch
May 15, 2004 10:22 PM
92CiviCJdMMX
Feb 4, 2004 11:38 PM
