Honda CR-V & Element 2WD & 4WD Element & CR-V
backup lights wont stay on in reverse of my 98 CR-V 5sp. man.
Old Dec 30, 2012 | 02:41 PM
sherrydemon's Avatar
Default backup lights wont stay on in reverse of my 98 CR-V 5sp. man.
When I put it in reverse gear the backup lights come on only if i put pressure on the shift ****, pushing it forward almost till it pops out, as soon as I let my hand off the backup lights go out . I have seen where the shift cable connects to the shift lever and when i push back on the shift lever the lights come on. There is a little slack there, can this cable be adjusted and how do I do that. I have searched online and cannot find out how to or if I can adjust the shift cable. Any suggestions or is it something else like the backup switch?
Old Dec 30, 2012 | 07:02 PM
NZ-DB8R's Avatar
Default Re: backup lights wont stay on in reverse of my 98 CR-V 5sp. man.
Is there a reverse switch located on the front of the gearbox like all other Bseries? Has a green and a yellow wire going to it, near the Clutch Slave Cyl
Triumphtigger
Jun 4, 2019 09:05 AM
SlamsItIn
Aug 17, 2013 09:38 AM
IsweatHONDA
Aug 8, 2007 06:20 PM
