z6 swap / missing hose for hose outlet HELP!
Old 08-18-2011, 09:40 PM
okBYE's Avatar
Default z6 swap / missing hose for hose outlet HELP!
Just finished my rebuild on a z6 that I bought a while back and I'm finally putting the motor in the car. After dropping the motor in and finishing wiring for the most part, I started putting in the hoses. I found 2 hose outlets that I had no idea where they went.
1. On the metal water pump hose there are 2 outlets, the one on the driver side of it connects to the IACV, and the other close to the thermostat I have no idea where it goes.
2. There are 2 hose outlets on the IM, one connects directly with the thermostat and is a larger outlet, the other is a small one the same size as the one I'm missing on that metal water pump hose.
pic:
If you can think of anything please let me know, thanks!
John.
Old 08-19-2011, 01:23 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: z6 swap / missing hose for hose outlet HELP!
Old 08-19-2011, 01:24 AM
okBYE's Avatar
If anyone needs any more pictures as reference please feel free to ask and I will do my best to do so. I really need this info because I'm so lost, thanks. lol
Old 08-19-2011, 01:26 AM
okBYE's Avatar
What about the hose outlet on the driver side of the metal hose from the water pump? leave it open as that diagram implys? lol
Old 08-19-2011, 01:28 AM
okBYE's Avatar
and also on that diagram where 3 hooks up to the IM, there is an outlet right next to that, thats one of the ones i am missing and that diagram doesnt show a hose going to that either.
Old 08-19-2011, 05:33 AM
Technical Hero
Some models had an oil warmer
Here is another setup as well
If you don't have either, loop, T or block it off
Old 08-19-2011, 06:06 AM
okBYE's Avatar
Is that going to the fast idle valve with the loop there?
h4x
09-11-2012 05:08 PM
RicharDC4
05-27-2009 05:45 PM
EGB18C
02-29-2008 06:26 PM
Hondatuner88
Welding / Fabrication
02-13-2008 06:56 PM
1991hb
02-14-2007 05:18 PM
Quick Reply: z6 swap / missing hose for hose outlet HELP!
