y8 dizzy on a z6!?!?!?!?!?!!?!?!?!?!?!?!?!
i want to know if a y8 distributer will work on a z6 motor the reason im askin is becouse my y8 blew and i got a z6 and want to now if it wil work.
sorry if this has bein covered before but i didnt find anything
Re: y8 dizzy on a z6!?!?!?!?!?!!?!?!?!?!?!?!?! (jdmracer12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmracer12 »</TD></TR><TR><TD CLASS="quote">yesserybob, fits like a glove
No, it doesn't.
You would only be able to use the top bolt, and the slot would need to be modified slightly. It is not a direct replacement.
No, it doesn't.
Re: y8 dizzy on a z6!?!?!?!?!?!!?!?!?!?!?!?!?! (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">
No, it doesn't.
You would only be able to use the top bolt, and the slot would need to be modified slightly. It is not a direct replacement.</TD></TR></TABLE>
^true. y8 dizzy will fit in a y7, b7, b8, but NOT a z6. only a z6 will fit a z6.
No, it doesn't.
Re: y8 dizzy on a z6!?!?!?!?!?!!?!?!?!?!?!?!?! (street_racer_NC)
Yup, that is a no. Only the top bolt works as previously stated. Requires some modification to work.
Wrong , it requires some modification in order to fit correctly. The bolt holes dont all match up right.
Re: y8 dizzy on a z6!?!?!?!?!?!!?!?!?!?!?!?!?! (97Ej6mike)
thanks for the information guess ill just swap all the internals into the z6 dizzy case becouse i dont want to cut plugs
Gloves come in different sizes... My hand does not fit a child's glove.. Where did this line even originate from?
Re: y8 dizzy on a z6!?!?!?!?!?!!?!?!?!?!?!?!?! (sageuvagony)
I have no clue where it came from. sorry OP didnt realize that they didnt work. I just assumed that the heads were so close it work. my bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_racer_NC »</TD></TR><TR><TD CLASS="quote">only a z6 will fit a z6.</TD></TR></TABLE>
Actually, you can bolt a d15z1 or d15b dizzy on a z6 head.
* B A N N E D *
Re: y8 dizzy on a z6!?!?!?!?!?!!?!?!?!?!?!?!?! (EK4k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK4k20 »</TD></TR><TR><TD CLASS="quote">u know waht is the best ECU to push a b16b? </TD></TR></TABLE>
pct
pct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sageuvagony »</TD></TR><TR><TD CLASS="quote">
Gloves come in different sizes... My hand does not fit a child's glove.. Where did this line even originate from?</TD></TR></TABLE>
OJ simpson case?
OJ simpson case?
Re: y8 dizzy on a z6!?!?!?!?!?!!?!?!?!?!?!?!?! (ddd4114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 »</TD></TR><TR><TD CLASS="quote">Actually, you can bolt a d15z1 or d15b dizzy on a z6 head.</TD></TR></TABLE>
it wont bolt in but it'll lock in.. the bolts dont line up
Re: y8 dizzy on a z6!?!?!?!?!?!!?!?!?!?!?!?!?! (muhaMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by muhaMan »</TD></TR><TR><TD CLASS="quote">it wont bolt in but it'll lock in.. the bolts dont line up</TD></TR></TABLE>
hmmm I could have sworn they were interchangeable... I must be confusing this with something else...
IVAN93EG
05-14-2006 11:23 PM
racerpat94
05-22-2005 11:07 PM
