y7 head on d15b2 block in 97 coupe
Old 06-30-2009, 09:58 PM
95lsteg9116's Avatar
Default y7 head on d15b2 block in 97 coupe
will the d16y7 head work on a d15b2 block... and still work in the 97 civic lx without changing the car back to obd1
Old 06-30-2009, 10:21 PM
owneyboy's Avatar
Default Re: y7 head on d15b2 block in 97 coupe
yeah it will, u will have to use a y7/y8 head bolt on the very back left ( intake side nearest to throttle body) mite run like crap... that head will raise compression to 10:5 almost
Old 06-30-2009, 10:29 PM
okay so i wont have to convert the car at all... and what about the crank posiion sensor next to the crank pulley... the b2 block doesnt have it bt the original y7 block did, will it affect the car at all..
Old 06-30-2009, 10:38 PM
owneyboy's Avatar
not sure u mite have a CEL? uh i never done that swap into a obd2 car but i have done it to a obd1 car...
Old 06-30-2009, 10:42 PM
okay well ill give it a shot.. any help or advice you can give me of how to take off a crank pulley... if i cant start the motor cuz its blown lol (id take it off to remove the oil pump and sensor to put it on the b2 block????
Old 06-30-2009, 11:27 PM
owneyboy's Avatar
use air/power tools or rent a chain wrench and wrap it around the pulley and loosen bolt
Old 03-31-2024, 12:36 AM
JaRow's Avatar
im curious im taking b2 internals inside a b6 block and the crank everything and using a y7 head im in an extremely bad spot and need to. kinda sucks but need to there are no b2s anwhere near me and no vehicle and there arnt any civics in any junk yards near whatsoever either, wouldnt d16 head bolts be shorter and possibly strip. a freind of mine tourqued it down to spec and it stripped it trying that, is the one bolt a diffrent spec i just want a reasoning ive done it to my b2 block before with all b2 bolts and wasnt an issue till a friend overheated it and it raised just curious dumb fun Honda ****
Old 03-31-2024, 12:58 AM
JaRow's Avatar
also can i just use the arp head studs i had for the original build will that hold instead of using the y7 bolt been waiting to use these arp head studs for awhile
civic coupe
01-30-2012 05:14 AM
Littleredsi
05-30-2004 10:06 AM
Quick Reply: y7 head on d15b2 block in 97 coupe
