wut should i run?
Re: wut should i run? (DragIIcivic)
id say mid 14's ive heard that the b16 tranny has closer ratios than the gsr and can yield lower times but thats only hear say i havent witnessed but i do know that it does have closer ratios from driving a gsr and si thats my .02
lata
lata
Re: wut should i run? (4g63turbo)
Check my sig. My car is a tank of an Si though. Also I am sure that the 555R's might be a little stickier than my yoko's, but I did hit a 2.0 This is with a Gsr trans i/h/e fpr chipped ecu and ignition +2 degrees, rear seats and spare taken out.
1 Post
Read my Sig....
1.99 60ft. 14.5@93mph
Intake\Exhaust
Stock Timing\Header\Hi-Flo Cat
~2000 Lbs
20in ET Drags @ 18PSI
Launching @ 5500rpm
Clutchnet Stage 2
B16a Trans (Y1 Cable)
I coulda cut a better 60ft.
Looking for 13.9 with Pulleys\Header\Advanced Timing\Tuned Cam Gears
Before I go Turbo in Springtime that is.
Suprdave
Intake\Exhaust
~2000 Lbs
Launching @ 5500rpm
Clutchnet Stage 2
Suprdave
i think the GSR dash adds like 20 horsepower doesnt it??? hehehe im just playing,..i think a gsr dash in a EG is one of the nicest mods you can do,..i will do the same wen i get my EG,..but to answer ur question...i dont think u will run any faster then 14.5,...good luck
miker01
35
07-03-2006 11:39 PM
