Wtfffffff....helpp
Wtfffffff....helpp
So im wondering how the hell my bolt that holds the alternator to the block fell out...i order a new one from honda...and it wont thread...so i look at my girls honda and im like oh look a smaller bolt can go all the way through....not on myne...i guess the eople who had it befor me decided to brake the bolt off into the block...(where the bracket bolts too)....wtff do i do?? ill never get a drill down there... any ideas please??
Re: Wtfffffff....helpp
Either get a right-angle drill to extract the old bolt or weld the bracket onto the block permanently. A pneumatic drill is your best bet when looking for a small drill to get into tight places. If you're just buying it to extract the bolt, you might just take the drill back to the store when you're done.
i was just thinking too i could loosen the motor mounts and jack the engine up..so the alternator would be at an angle too...or would it not jack up high enough??
I doubt you'd be able to angle the motor enough without risking damage. You'd probably have to disconnect almost everything, separate the motor from the tranny and lift the motor out. I actually listed lifting the motor as a possible solution but deleted it when I figured it would be best to try an angle drill first.
dbailey
13
01-20-2010 12:25 PM
