Would any b series header fit on b16a2 ?
would 94 up integra LS aftermarket fit onto b16a2 engine? Because LS header is a non vtec b series header. just need to confirm this before i place an order. thanks.
Re: Would any b series header fit on b16a2 ? (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">anyone else knows for sure ?
bump</TD></TR></TABLE>
Luserkid does know for sure.
It will fit, he's just stating that some of the B series have trouble fitting, like I'm not sure if a B16a2 header will fit on an ITR due to the B16a2 header being not as tall from the ports to the oil pan as the ITR is.
Though a B16a2 is the smallest...so yeah, it'll work.
All Motor Mentor
1 Post
It will work but the Ls motor has a taller deck height so the header will hang low on your b16a. If it's slammed you'll probably end up whacking it on a few speed bumps.
Re: Would any b series header fit on b16a2 ? (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez »</TD></TR><TR><TD CLASS="quote">Why not just order one from a Del Slow B-tak or a 99-00 Si?</TD></TR></TABLE>
Darth ModerVader
Re: Would any b series header fit on b16a2 ? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">In your case youll be fine. </TD></TR></TABLE>
It will be fine in the sense that it will bolt to the head and clear the oil pan, but if the current setup is a B16A manifold or header and is bolting up to the existing cat, there will be an issue due to the fact that the LS header uses a different angle for the collector flange.
b20SedanEF
05-03-2015 08:29 PM
SMSP
31
05-09-2005 05:56 PM
