would an "ABS" CV Half Shaft work on a Non-ABS Civic??
Re: would an "ABS" CV Half Shaft work on a Non-ABS Civic?? (onesecplz)
I have non-ABS axles running with my ITR 5-lug (ABS). No problems for me. I would expect you could go the other way as well.
Re: would an "ABS" CV Half Shaft work on a Non-ABS Civic?? (ChiBoy)
the only difference between an abs axle and a non abs axle
is a serrated ring aroung the outer cv joint, and that is only pressed on
to prove it try taking a hammer and knock off the abs ring
it should knock right off with a little coaxing
