won't start after change oil pan GSKT
like the tittle say. Last week I rebuilt my bottom end for cheap I reuse the oil pan gasket and start leak. Yesterday I remove the negative battery terminal, remove the downpipe from the V-band and changed the gasket.
When I went to start it, crank but not start. Check light comes with the switch and turn off. I find no spark, switch to my spare dist. and nothing, check for 12v in the dist. plug on both sides of the BLK/YEL wire and is fine.
Any suggestion or ideas are welcome.
Re: won't start after change oil pan GSKT
Performed the test: 12.4v at coil and ignitor. Put the other distributor and the same readings.
What other part can cause this situation?
BuddhistPriest87
Honda Civic (2006 - 2015)
02-10-2012 02:40 PM
debogsr
03-25-2008 10:23 PM
Hiii Im TYLER
04-10-2007 12:34 PM
