wiring in new primary o2 sensor code 41 help
Old 10-29-2012, 05:58 PM
civicguy395's Avatar
Default wiring in new primary o2 sensor code 41 help
i have a 98 civic ex with a b-swap obd2-obd1 conversion anyways i wired in this o2 sensor today and now i get a code 41 on the harness side i have a green wire a white wire and 2 black wires on the o2 sensor i have a black wire 2 white wires and a brown wire anyways i was wondering which of the 2 wires was the heater circuit on the car color code the green white and 2 black wires no o2 sensor code but the heater circuit code is thrown
Old 10-29-2012, 07:05 PM
Default Re: wiring in new primary o2 sensor code 41 help
this is how i wired it to the plug green - white, gray - black, white-white, black-black
any ideas as to which 2 i have crossed?
code 41
Old 10-30-2012, 04:13 AM
bump
Old 10-30-2012, 07:57 AM
Black (heater wire) --> White
Green (ground wire) --> Gray
White (signal wire) --> Black
this is the only kind of wire by color code i could find i would go rewire mine this way if it wasn't raining outside i assume this is the correct wiring for a Bosch universal o2 sensor
Old 10-30-2012, 03:52 PM
i had a chance to rewire my o2 sensor this way and so far no more check lights seems to work great (problem solved)
Sereth
Honda Civic (2001 - 2005)
08-23-2017 01:12 AM
b18cEF9
13
05-08-2005 04:45 PM
c0nspire
11-01-2004 07:37 PM
Cornwhiskey
05-20-2004 08:53 AM
xmd
10-12-2003 10:38 AM
Quick Reply: wiring in new primary o2 sensor code 41 help
