wiring gsr cluster in eg ???
i found the wiring diagram which is below, but before i start chopping wires and such i had a couple questions on the the extra plugs that were left. on the integra wiring, what happens to the third blue plug? no wires on that plug are used? is it just left out?. and my last question is the yellow plug, is it plug and play because the yellow plug is the same on both wiring? is this plug left out too? if used do i need to repin it?
i searched old threads but noone mentioned these plugs
Integra Blue Left Side Plug (13 pins)
1. BLU - Tach signal
2. GRN/ORG - Check engine indicator
3. YEL/RED - Oil pressure switch
4. -
5. WHT/BLU - Charge indicator
6. -
7. YEL/GRN - Coolant temp
8. BLK - Ground
9. RED/BLU - Cruise control (if you have cruise)
10. YEL - Hot
11. -
12. PINK - Maintenance (not used)
13. -
Integra Right Side Blue Plug (16 pins)
1. GRN/RED - E-Brake signal
2. RED/GRN - High beam
3. GRN/YEL - Right turn
4. GRN/BLU - Left turn
5. -
6. BLK/YEL - Power
7. RED/BLK - Power
8. RED - Power
9. BLU/RED - ABS (not used)
10. GRN - Trunk switch
11. ORG - Vehicle speed sensor
12. -
13. BLU/WHT - Low fuel (not used)
14. YEL/WHT - Fuel gauge
15. LGT. GRN/RED - Door switch (not used)
16. RED/BLU - Seat belt
Civic Left Side Grey Plug (12 pins)
1. YEL/WHT - Fuel gauge
2. YEL/BLU - Vehicle speed sensor
5. WHT/BLU - Charge
6. YEL/RED - Oil pressure switch
7. -
8. BLU - Tach signal
9. -
10. BLK/YEL - Power
11. RED/BLK - Power
12. RED - Power
Civic Right Side Grey Plug (10 pins)
1. RED/GRN - High beam indicator
2. GRN/RED - E-Brake signal
3. -
4. -
5. GRN/ORG - Check engine indicator
6. BLK - Ground
8. YEL - Hot
9. GRN - Trunk switch
10. BLU/WHT - Seat belt
_______
4. -
6. -
8. BLK - Ground
10. YEL - Hot
11. -
13. -
5. -
6. BLK/YEL - Power
7. RED/BLK - Power
8. RED - Power
12. -
5. WHT/BLU - Charge
7. -
9. -
10. BLK/YEL - Power
11. RED/BLK - Power
12. RED - Power
3. -
4. -
6. BLK - Ground
8. YEL - Hot
_______
lsismore
01-13-2006 01:14 AM
DB8
06-10-2002 07:53 PM
