wire identification? eg hatch engine bay
anyone know what the blue/red stripe wire with a bullet connector on the end coming from the driver side harness is for?
also, i recently removed my dash to fix some theft damage, and when doing so i did the wire tuck thru the door harness outlet and down the inner fender. when i put my dash back in and together, i tried turning on the air and it wont work. the lights on it work and everything but it wont blow any air
Modified by AmbiguousCivic at 7:48 PM 5/14/2008
Re: wire identification? eg hatch engine bay (AmbiguousCivic)
not sure what wire it is but as far as the air you might have blown your compressor fuse putting your harness back in
Re: wire identification? eg hatch engine bay (vtecb18c)
any thoughts on which one it is/location? and is there any way to tell if a relay is bad other than to swap it out with a known good one? oh yea, and when i took my dash out, i removed my ac compressor and all components to it....dunno if that could have any ill effects on it
allricedout
12-28-2006 07:38 PM
