Window Problems
Old Jul 21, 2004 | 08:56 AM
EK_HYBRID_'s Avatar
Default Window Problems
On my drivers side window when i go to roll my window up all the way it stops w/ like a 1/4 of the way left to roll up and like makes a really hard/loud noise. I tried looking down into the panel and it looks like 3 of the "teeth" if that's what you wanna call it are broken.....my question is would that be the window regulator that i would have to replace or are there other parts i'd need to get????
Old Jul 21, 2004 | 11:06 AM
j0nptw's Avatar
Default Re: Window Problems (EeeJaySixxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EeeJaySixxx &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you need a whole new window assembly...it doesnt really come apart in pieces. i have one if youre interested</TD></TR></TABLE>
either that or find one in a junkyard and try some custom work
Old Jul 21, 2004 | 12:37 PM
HXvtec's Avatar
Default Re: Window Problems (j0nptw)
same thing happened to me. what i did is take the window apart so its 2 peices. u have to hammer the bolt thing thats in the middle. i then took a screw and a nut throw the hole and tightend it really hard. so far its been working but i need to get another one. just go to a junkyard and buy the whole new assembly. i found one on ebay for 60 bux.
Old Jul 21, 2004 | 03:28 PM
EX-T's Avatar
Default Re: Window Problems (NA EJ6)
First off...
It's your window regulator. It's really easy to fix and self explanatory once you get the door panel off. There are a few bolts that you have to take off to get the window off of the regulator and then a few more bolts to get the regulator off of the door skin. Take the window off the regulator and pull it out of the door, b/c otherwise if you have tint you will scratch the tint all up trying to get the regulator out. I scratched my tint up doin' it and it was my driver side window regulator. Let us know what happens.
BTW... what year is your car?
Old Jul 22, 2004 | 06:55 PM
EK_HYBRID_'s Avatar
Default Re: Window Problems (DSeriesBKilla)
THE $40 IS FOR THE REGULATOR...
EK_HYBRID_'s Avatar
1996
Old Jul 22, 2004 | 08:42 PM
Chillin94hatch's Avatar
Finding one at a junkyard isnt always the easiest process. I actually went down to the strip in philly this morning looking for one to replace my bent one (a thief attempted to slim jim my **** and bent it) Anyway, it all depends on what year your car is and how many doors. I got 94 cx hatch and my first mistake was I located one at the yard off a 4 door and it doesnt fit. Im still searching for the one that will fit in my hatch. I also need the rubber window channel gasket that keeps the glass in line. It is a pain in the *** and it is god damn frustrating. Does anyone know if a 2 door regulator is identical to the hatchback one? I need a driverside one and I need the damn rubber gasket....
Old Jul 23, 2004 | 12:27 PM
EK_HYBRID_'s Avatar
where are you located???
lokuntry
Aug 3, 2008 04:23 PM
george34
Sep 27, 2006 07:23 PM
Sean @ ESG
14
Sep 9, 2005 09:21 PM
crx_ef8
Nov 14, 2004 06:18 PM
iwhichisme
May 2, 2003 11:28 AM
