Wilwood Brake Kits?
1 Post
Wilwood Brake Kits?
I'm wondering if someone can help me. With Wilwoods Dnyalite Big Brakes for the 90-00 Civic (part #140-6310) can they fit under a 15" rim? (steelies are 15", rims are 16")
If not I'm going for a Fastbrakes front kit.
Also about the rear brakes, are 92-95 Civic Si or Integra disc brakes bigger?
Future Texas Boy
Re: Wilwood Brake Kits? (The G2 Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The G2 Racer »</TD></TR><TR><TD CLASS="quote">I'm wondering if someone can help me. With Wilwoods Dnyalite Big Brakes for the 90-00 Civic (part #140-6310) can they fit under a 15" rim? (steelies are 15", rims are 16")
I think you need at least 16`s.
Get the FastBrakes Kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The G2 Racer »</TD></TR><TR><TD CLASS="quote">If not I'm going for a Fastbrakes front kit.
Also about the rear brakes, are 92-95 Civic Si or Integra disc brakes bigger?</TD></TR></TABLE>
Go with fastbrakes, or go with teg front brakes for less, yes the rears are the same....
if you're not going to the track (the twisty one) go with a teg setup and aggressive pads, i don't care what anyone else says, they are wrong, you don't need big brakes for the street.
Re: (jwn7)
No Big Brake kit would fit under 15" wheels.
You need at least 17", but some 17" won't clear, some 16" would, depends on the wheel design.
I would highly look into Rotora Big Brake kits. http://www.rotora.com
Teg brakes work great in the rear, but the front ones are only slighty bigger than regular civic brakes.
If you want to go up to larger rotors and run 15s check these out for up front http://www.fastbrakes.com/prod...FBH03 If I wasn't so broke these are the front brakes I would roll.
STeel braided lines, teg mastercylinder and propotioning valve help alot.
http://tech.hybridgarage.com/tech/brake2.html
1 Post
Re: (FuZioNxMaxBoost)
I do a lot of track so I think I'll benifit from the Fastbrakes front kit. I'll put Teg brakes in the rear.
Is the ITR master cylinder and propotioning valve bigger then the other Integras?
Future Texas Boy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuZioNxMaxBoost »</TD></TR><TR><TD CLASS="quote">No Big Brake kit would fit under 15" wheels.
Don`t be stupid.
I run an AP Setup on my EG with 15`s and the Fastbrakes Wilwood Kit on my EK w/ 15`s.
Big phucking brakes under a 15" wheel:
Don`t be stupid.
You need at least 17", but some 17" won't clear, some 16" would, depends on the wheel design. </TD></TR></TABLE>
that just hilarious
that just hilarious
Re: (vtecvoodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo »</TD></TR><TR><TD CLASS="quote">
Don`t be stupid.
So how big is that rotor and caliper? Sorry, when I think of Big Brakes, I think of Brembo's and Rotora's.
I stand corrected, but it really depends on your wheel.
The original poster asked if they fit under his 15" steelies... not too sure about that one@
Some 18" wheels won't clear bbk's.
Modified by FuZioNxMaxBoost at 11:00 PM 10/23/2003
Don`t be stupid.
BBK's </TD></TR></TABLE>
oooooooooooh HRE's
damn how much was the setup on that thing???
HRE + Brembo =
oooooooooooh HRE's
HRE + Brembo =
blkgsr03
15
06-14-2007 07:42 PM
Spade
13
11-04-2003 11:37 AM
