Will RSX injectors work in my sol???
Just as the topic says...i have a 97 sol with a Y8 and my buddy is selling the stock 320's out of his rsx...will they work in my car with no modification or will i have to do some rewiring???
Also, what would you guys pay for stock RSX injectors? i believe they are out of his type r motor, not possitive tho.
Thanks in advance
Thanks in advance
Re: Will RSX injectors work in my sol??? (ADVAN EG2)
why do you want larger injectors......do you have a turbo with like 3psi......do you plan on tuning it.....what is your reasoning.
that much fuel will make your 1.6l run like **** and probably mess up sensors and give you shitty gas mileage
Re: Will RSX injectors work in my sol??? (DirtySol)
i figured i would get some of these questions...im planning on boosting again, and yes it will only be around 5 psi untill i get a built block. I just figured this would be cheaper then getting some rc 310's that i would just be using for a short time.
Re: Will RSX injectors work in my sol??? (sohc_sol)
Anyone want to actually answer my question with an answer instead of another question??? i would really appreciate it!
you might have to wire in the OBD2b2 injector pigtails but it is not very hard.....just be sure to solder the joints.
no, the IM manifold end will fit but the fuel rail end of the injectors won't. unless you get someone to machine it down but ...ymmv
your mileage may vary
I bought a set of used RC injectors. See the link for a pic. The input side (side closest to the electrical connector) is too big and won't fit into the D fuel rail.
Options would be to machine the injectors down (maybe) or open up the fuel rail.
https://honda-tech.com/zerothread?id=1260744
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_sol »</TD></TR><TR><TD CLASS="quote">ymmv???
i take it you have tried this?</TD></TR></TABLE>
