will paypal 20$'s who can help me with my problem (99 ek owners )
1 Post
I'am dead serious
well 99 ek
99 ex coupe engine harness
obd1 conversion
jdm gsr ecu
problem
car is cranking but no spark , no fuel pump
when i turn the key to the on (III) I only get a oil light on my cluster my main relay doesn't click 2 times like it should
got a brand new main relay from honda yesterday check all my engine grounds and use sand paper on the ground for good contac and nothing I need steps and procedure on how to find out whats wrong
THANKS
well 99 ek
obd1 conversion
jdm gsr ecu
problem
THANKS
Re: will paypal 20$'s who can help me with my problem (super-hatch)
if it doesn't click twice then that means the fuel pump dosent prime, check if the pump is getting voltage, and also check the fuel pump relay as for the spark check your coil, cap, and rotor good luck
1 Post
Re: will paypal 20$'s who can help me with my problem (ej1_lsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej1_lsvtec »</TD></TR><TR><TD CLASS="quote">if it doesn't click twice then that means the fuel pump dosent prime, check if the pump is getting voltage, and also check the fuel pump relay as for the spark check your coil, cap, and rotor good luck</TD></TR></TABLE>
where is the fuel pump relay located ? u mean the main relay ? btw i will test my dizzy with my friends car tomorrow
1 Post
ow and btw on those 2 dead end plugs behind the manifold wich one is the one thats suppose to have the cap ??????? u know the dead end plugs?
1 Post
dead end plugs right behind the intake mani there are 2 of them with a bunch of yell/black wires coming out of it
whats the problem? could also be the ecu you might want to barrow one
Modified by ej1_lsvtec at 9:36 PM 2/14/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super-hatch »</TD></TR><TR><TD CLASS="quote">dead end plugs right behind the intake mani there are 2 of them with a bunch of yell/black wires coming out of it </TD></TR></TABLE>
Those aren't dead end plugs. They are "junction connectors". One of them distributes power to several wires, the other ground. The caps must be plugged in.
Good Luck.
Good Luck.
1 Post
Re: will paypal 20$'s who can help me with my problem (sql_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sql_civic »</TD></TR><TR><TD CLASS="quote">Those aren't dead end plugs. They are "junction connectors". One of them distributes power to several wires, the other ground. The caps must be plugged in.
Good Luck.</TD></TR></TABLE>
in wich junction connector ? they are 2 of them , wich one should have the cap ?
ow btw I try 3 differents ecu and same ****
What are the wire colors going into each connector? Does one have Yel/Blk wires while the other uses Grn/Blk wires? If yes, then cap both. One is for grounds and the other is for power.
Get a Helms - it helps here.
Re: will paypal 20$'s who can help me with my problem (EE_Chris)
if you look behind the glove box. right above the ECU. you will see a small black box (relay) thats your main fuel pump relay. my friend had same problem and he replaced it and that was it.
Re: will paypal 20$'s who can help me with my problem (JDMFantasy2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFantasy2k »</TD></TR><TR><TD CLASS="quote">dead battery
don't laugh, happened to me</TD></TR></TABLE>
or that lol
or that lol
check the conversion harness.. maybe you got the wrong one.. check if all the wire from the car is conected to some wire on the harness. if you got your car harness conected to the empty spot on the conversion harness email me and i show u some pic...
stickerguynyc@yahoo.com
Re: will paypal 20$'s who can help me with my problem (RATED EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RATED EG »</TD></TR><TR><TD CLASS="quote">if you look behind the glove box. right above the ECU. you will see a small black box (relay) thats your main fuel pump relay. my friend had same problem and he replaced it and that was it.</TD></TR></TABLE>
aka the main relay. which he said he replaced already
Re: will paypal 20$'s who can help me with my problem (spork motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports »</TD></TR><TR><TD CLASS="quote">i dont have paypal can you send a check?????? </TD></TR></TABLE>
go buy your ls1 and do us a favor and get off ht.
1 Post
replaced with a brand new one from honda and same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sql_civic »</TD></TR><TR><TD CLASS="quote">Both junction connectors should have caps. It's the cap that completes the circuit.</TD></TR></TABLE>
only one have the cap, I'am 100 % sure that thats my problem i will see whats up today after I get off work
brand new battery cant be that, about the 20 $'s no one gave me a good answer soo yea I get to keep them
1 Post
well today i try to start it i didnt want to get deep in to it since is damm cold and my car is under the snow soo icant really work on it
i try that cap thing and now I can heard the fuel pump and the 2 clicks I didnt want to crank it bc is open header
