Will gsr rotor and caliper fit on eg knuckle???
Re: Will gsr rotor and caliper fit on eg knuckle??? (lazyguy)
It will if you have the SI eg but if thats the case it is the same calipers and rotors as the integra. If not you can use knuckles from a 92-95 EX or SI. Or from a 94 up integra.
Re: Will gsr rotor and caliper fit on eg knuckle??? (hatchdrvr)
I do not think the Civic EX/Si from '92-'95 have the same front caliper as the '94-'01 Integra.
The Integra caliper is larger and uses a larger pad... correct me if I am wrong.
I do believe those all share the same front rotor though.
Note-
'94-'01 Integra brakes are the same front and rear for each model, except the Type R.
So that means RS=LS=SE=GSR.
You can bolt Integra calipers to the EX/Si 92-95 knuckle
You can also bolt ITR calipers (mill 4mm off mounting side) and use 93-96 Lude Vtec rotors (redrilled to 4x100) to get an ITR 11" setup and keep 4x100 lug pattern on Integras 94-01 and Civic EX/Si 92-95
Note-
Re: Will gsr rotor and caliper fit on eg knuckle??? (owen_the_soyboy)
Note-
Note-
Solbros Owns Me
Re: Will gsr rotor and caliper fit on eg knuckle??? (IhateMy93BlackHatch)
the only 92-95 Si/EX rotors that are the same size as Teg ones are the models equipped with ABS. My 94 Si without ABS has same size rotors as LX, DX, VX, etc., except I have rear disc.
I thought the Ls Rotors were 9.75 and the GSR were either 10.2 or 10.4. Thats what someone told me last week
Re: Will gsr rotor and caliper fit on eg knuckle??? (DaiJekBok)
all 93-95 have 10.3 rotor. only si eg w/abs have that size rotor also. my 92 si has the crappy civic brakes but it has rear discs
fryman
12-28-2009 02:46 AM
