Will del sol sway bar fit ek??
Re: Will del sol sway bar fit ek??
Yes it will fit as the eg dc ek rear sway bars are all interchangeable
But if ur car didn't come with one u will need the d brackets with busings with the backing plate as well as the endlinks with lcas that have the hole with threads on em so that the endlinks will bolt up as well as the 12&14mm bolts
You really don't need anything for such a small bar.
Also, being as he has a EK, he doesn't need lca's.
Op, if it looks like a 13mm, I would bet it is a Si sway bar to begin with.
He does need the backing plates where the d brackets connect to as it connects the d brackets 2 the Lower subframe
A rear subframe reinforcement brace isn't necessary nor was it ever mentioned ^^^
And he does need LCas as that where the endlinks connect to
And 99-00 civic si EM1 chassis use 15mm thick rear sway bars stock just like the gsr and vtec model del sols
Never said anything about a subframe brace.
No he does NOT need difference lower control arms. ALL 96-00/EK rear lower control arms are the same. All have a a hole for the endlinks.
No they don't. 99-00 civic SI's run a 13mm rear sway bar, however, so infomation poped up to say that 2000's came with a 14mm rear sway bar.
Not to be a dick, but you need to get your information straight before you post. I have SI sway bars on my car. I know what you need and what you don't need to install them.
No Del Sol sway bars will not fit a EK, I wish they did. On my Del Sol I had Eibach sway bars and wanted to put then on my EK but after a talk with a rep at Eibach they are different as far as the bend in the sway bar go and will not bolt up. I needed up putting Si sway bars on instead. GSR and ITR sway bars will work.
EDIT, I just looked around, they do seem to not run the regular endlinks.
That is the issue. An OEM sway bar should work just fine.
All EG/DC/EK sway bars are interchangable. The difference is just the subframe brackets and Endlinks.
This guide should clear a lot up.
http://www.socalcivic.com/forum/showthread.php?t=17313
Sway Bar size guide
http://www.trinituner.com/v3/forums/...c.php?t=364098
Sway Bar size guide
phantom_sol
04-24-2003 01:27 PM
