will d15b8 distributor fit d6z6?
will d15b8 distributor fit d16z6?
my question is does the d15b8's (stock CX 8 valve motor) distributor fit on a d16z6? I have asked a few people and have been told you gotta ghetto rig it a little but you can get it to work. If it can, is it a perfect fit? What kind of problems will i run into? thanks for the input.
Re: will d15b8 distributor fit d16z6? (BauleyCivic)
basicaly only one hole will partialy line up. the other two have to modified. meaning you have to cut the ends off of the ears and use big washers. it looks really ghetto after its done. if youlook you can find z6 or z1 dist for cheap. thats the ex,si, and vx, they all use the same dist. so much easier in the long run, i assure you, i went throught the same thing. just find a td-42u dist.
Petah
06-30-2003 11:48 PM
