will a 92-95 exhaust fit a 99 hatch?
ok sorry for the stupid post but i did a search and couldnt come up with anything...so will a 92-95 civic hatch or coupe exhaust fit a 99 hatch.
like i said i know we have probably talked about it before so sorry just if a few people could answer that would be great...
thanks!!
thanks!!
Re: will a 92-95 exhaust fit a 99 hatch? (phatcivic99)
You will have to add about 2 inches to the center pipe. The bend around the gas tank and the hump over the rear suspension are very similar so no modds should be needed there.
The exhaust on my eg was originally from an ek and I had to cut about 2 inches from the center pipe so it would fit... Everything else lined up no problem.
Location: just when you thought you were different, WA, NWforLIFE
actually, it will fit very good if you have a swap in your car...on my car, i have a bseries motor with a b16 exhaust manifold connected to a gsr *or any civic integra coupe* catalytic converter, and a 92-95 si hatchback exhaust. the setup bolts in perfectly, and you dont have to worry about unclean welding, extending, or any other money wasteful mods. hope this helps
Re: will a 92-95 exhaust fit a 99 hatch? (kidkombo)
yeah i have a ls with a dc 4-1 header. so i wont have to do any mods then
i have found that with this header the exaust is now pulled closer to the front. should this be or did i do something wrong.
thanks for the help
thanks for the help
on my original original set up when i got my swap was an extened ls header....and since you have an ls motor, your probably used an ls header that wasnt extended...when you do this, you will have clearance problems on the b pipe where it bends to toward the right rear tire.....
also, what also causes the shortness is your catalytic converter, it might be too short, you gotta use a coupe cat to make enought clearance...in order for your exhasut to perfectly bolt up with no mods, you gotta use a b16 header, its longer than the gsr and.......then.....get the coupe cat, and 92-95 si catback and youll be gravy! i hope this helps even though i think im repeating myself...
lol
lol
thanks for the help
thanks for the help
dang, i forgot to ask you, what kind of 4-1 header? if its an ls header, it will be short, as well as the gsr, that is most likely your problem, the cure?
B16 header! and a coupe cat
yeah well that sound good and that makes sence but i just spend a crap load of money on this set up so i have to keep it. haha.
thank you for the info you solved the banging in my rear after i put the dc ls header on. now is there a way to get the banging out. and i plan to do an hks or apexi exhaust in the near future. will this banging still happen. is there a way to get around that.
thank you for all your info
peace
peace
Mrbigaznboi
05-29-2009 02:02 PM
flatblack-h22
02-18-2008 05:22 PM
cj_140
04-25-2007 01:07 PM
shermanyang
02-04-2004 08:09 PM
95cx
12-04-2002 01:56 PM
