will 2001gsr brakes fit on 96 civic
Please help!
I have a 96 civic HB and want to install the 2001 gsr brakes(front and back): Will it fit onto my car without using the abs?
If you have any experiene or knowledge on this subject please reply
Re: will 2001gsr brakes fit on 96 civic (EkCivicHB96)
Will it be ok to use my stock m/c and booster with the gsr brakes?
Thanks guys
Thanks guys
Re: will 2001gsr brakes fit on 96 civic (kommon_sense)
OK,
I've installed only the back brakes(with the gsr e-brake line) today to try it out.
With the rear end jacked up, I spin the wheel. The brakes are rubbing against the the disc with a low "siiggggsh" sound and makes about 2-3 rotations.
Questions:
1) Is it normal for the brakes to be rubbing against the disc or spin freely?
2) If it's not normal, could it be due to the fact that i am using the gsr e-brake line? It was too short but i've lossen the line up until the black insulation of the wire, insde the e-brake line, was only showing a 1/2 inch . This was done to the line attached to the back of the e-brake handle.
3) Or the fact that I haven't changed the M/C and the booster to match the brakes?
Any inputs will be apreciated
[Modified by EkCivicHB96, 1:04 AM 1/29/2003]
Questions:
1 Post
no, not at all. they won't push enough fluid to the calipers and you *may* actually end up with brakes that are worse than what you have now.
I had 5 lug and used my stock MC/booster and it was fine. It had the same pedal pressure as a stock civic, but the brakes were sooo much better.
You don't need to upgrade, but it's always recommended.
Re: will 2001gsr brakes fit on 96 civic (fowler)
what car did the brakes go onto? What size was your stock mc ? there is a reason that they don't use the mc from the dx/cx/vx on the ex/si.
1 Post
And I understand there is a reason why they don't use the smaller m/c. I never said that it was in any way superior to that of an ITR or other Integra with a 15/16.
But it did serve well enough for me to say that you don't have to rush and get a new MC/Booster. It will work fine for the time being.
Thanks for the reply fowler
I'll try that
So, are you still using your stock m/c and booster?
btw the brakes do work alot better already, I will get around to change out the fronts sometime next week.
I'll try that
1 Post
Actually, I sold that car before I had a chance to switch that stuff out.
My friend upgraded his car to a 15/16 Mc/booster and it made a world of difference. Brakes are alot firmer. Good stuff
I have all that stuff from a totaled gsr.......Does everything bolt right up?
Or is there something I should know before trying to swap it out.
Also, is there anything else I need to change out besides the m/c and booster.
Viet
Viet
almost everything bolts right up. my understanding is that you need to bend an re-flare the brake lines to accomodate the gsr mc/booster. However other than that, it is all a bolt-on affair.
Drew314734
10-31-2011 01:45 PM
WhiteEkCivic
08-29-2007 09:59 AM
