Why to replace B18C1 Mani Before Swap?
I was told that before swaping a B18C1 into an EG, it would be best to replace the mani with a Type R/Skunk 2. My question is why? Not only because of the gains, but I think it had to do with wiring? Not sure...
Re: Why to replace B18C1 Mani Before Swap? (D G A F)
well if you replaced it you wouldn't have to wire up the IABs, but it really doesn't matter if you don't wire them, you won't throw a code or anything. That is the only difference in wiring that I can think of.
I did it after my swap and all I can say is it was worth it! Its a fairly cheap upgrade and opens up some space since you wont need some of the junk the old manifold needs for smog purposes.
I went with BLOX. Check out their manifolds...basically Type R/Skunk2...I went Blox on the manifold and skunk2 throttle body.
ekhatch978
05-14-2007 04:00 PM
GsR HtCh
11-06-2003 02:20 PM
