Who is running 215/45/16 Azenis on thier 99/00 civic's?
I am wondering if they are going to rub on my car? I have read that these are really wider than most 215/45/16's . They will be going on a 7" wide rim.
Thanx
Thanx
Re: Who is running 215/45/16 Azenis on thier 99/00 civic's? (EG-cellent)
I tried it back in September and it didn't work for me. I had a 16x7.5" wheel 43mm offset and 215/45x16" Azenis. Their tire should be labelled a 225/45x16" or even 235/45x16" they are really wide tires. I know someoe with an Integra who got his to work finally. 16x7" 43mm offset, 2 degrees negative camber front and 2.5 degrees rear, and really stiff springs.
Re: Who is running 215/45/16 Azenis on thier 99/00 civic's? (CivicSiRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiRacer »</TD></TR><TR><TD CLASS="quote">I tried it back in September and it didn't work for me. I had a 16x7.5" wheel 43mm offset and 215/45x16" Azenis. Their tire should be labelled a 225/45x16" or even 235/45x16" they are really wide tires. I know someoe with an Integra who got his to work finally. 16x7" 43mm offset, 2 degrees negative camber front and 2.5 degrees rear, and really stiff springs.</TD></TR></TABLE>
So on a 99 coupe with a mild drop, I feel 16 in rims look best. But yet azenis only come in 215/45/16 or 205/55/16, which is going to give me least rubbing issues?
Re: Who is running 215/45/16 Azenis on thier 99/00 civic's? (junglerunna02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junglerunna02 »</TD></TR><TR><TD CLASS="quote">Thats pretty beat, what would be the least likely to rub, a taller or a wider tire?</TD></TR></TABLE>
no clue.
but rubbing aside, 205/55/16 tires will look retarded on a civic.
no clue.
Re: Who is running 215/45/16 Azenis on thier 99/00 civic's? (Chris y0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">
no clue.
but rubbing aside, 205/55/16 tires will look retarded on a civic.</TD></TR></TABLE>
Thats what I was thinking the sidewall is just way to tall.
no clue.
BACK FROM THE DEAD
I actually ended up going with the Dunlop fm901 in a 215/45/16 tire and they do not rub at all. This is about a 2.25 drop with coils so depending on your drop and wheel offset they should not rub.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-cellent »</TD></TR><TR><TD CLASS="quote">BACK FROM THE DEAD
Well my drop is about 1.5 inches on my 99 coupe. I wanted to run 16x7's. But I also wanted to run azenis. There tire size is real limited for 16's. Because they only come in 215/45/16 or 205/55/16.
i have 205/50/15 as well how much is your car lowered just wondering, wanted to lower this summer at most 1.5 inches what is urs rubbing at?
no clue.
Whats your rim and tire setup?
no clue.
Re: Who is running 215/45/16 Azenis on thier 99/00 civic's? (jeddy0120)
i don't know how much my car is lowered exactly, but i would guess 2.75
my setup is 15 inch slipstreams with 205/50/15 azenis
FrostyDC4
04-02-2005 11:03 AM
