Who puts together a half decent turbo kit?
I've just been looking around for a decent turbo kit for a D16Y8, and have found a ton of sites that have kits put together for them. I'm looking for something reliable (no ebay crap) for a daily driver that would be running under 10 psi of boost. Something that comes with pretty much everything (injectors, oil lines, etc) except an ECU would be preferable.
Any recommendations would be awesome.
The Grumpiest
Re: Who puts together a half decent turbo kit?
What does 10PSI of boost mean when you don't even know what turbo you're running? Where do you people get this stuff?
Try Greddy. Edelbrock. GoAutoworks.
Then go to the Forced Induction section and read the FAQs three times.
OK sure, my main goal is reliability, which takes most precedence in this case, power I would like to be more then 200 hp at the crank, but I'm not expecting a lot, price I would like to keep less then 2k, but the less the better (as always) The bottom end of the motor has 127k km on it now. the top end I just rebuilt and ported less then 200 km ago
Retired Moderator
Then i would get the go-autoworks street kit
http://www.go-autoworks-store.com/gostkit.html
Edit: to save your engine, you must do the oil porting to prevent starvation if you go to or past 200hp.
Ive seen alot of Y8's blow cuz of this. Rod bolts should be considered as well.
Might as well just do it cuz once the power gets ahold of ur ***, you'll want more boost. Happens to us all.
TurboB18C1
07-13-2002 07:19 PM
