Where is my MAP sensor?! JDM B16A and a 93 CX hatch.
I have an empty plug on my EX harness, the CX has the same empty plug, but I can't seem to find something to plug it into. My ECU is throwing the MAP code and I'm guessing that my MAP simply isn't plugged in, since I can't seem to FIND IT!
Any suggestions/help in finding it? PICTURES would be fantastic.
Thanks!
Thanks!
Re: Where is my MAP sensor?! JDM B16A and a 93 CX hatch. (civicscantdrift)
Thanks!
Thanks!
Re: Where is my MAP sensor?! JDM B16A and a 93 CX hatch. (TurboB16aEG)
if its a 1st gen it might be hanging under the intake manifold...i have seen them zip tied there before since it is usually on the firewall
Re: Where is my MAP sensor?! JDM B16A and a 93 CX hatch. (delslow94)
It is a 2nd Gen B16A (hydro trans, right?? first gen is cable?)
I don't see anything like that on top of the IM. What does it look like? How many wires are going to it??
Thanks~~
Thanks~~
Thanks~~
Thanks~~
[Modified by TurboB16aEG, 11:02 PM 2/26/2003]
The JDM b16a wont come with a map sensor since its mounted on the firewall on the jdm civic. Just use your dx MAP sensor, located on top the the throttle body ( plug with three wires, held in by 2 screws) and mount it to your firewall and run the vacuum hose to the jdm throttlebody.
[Modified by Gray EG, 11:29 PM 2/26/2003]
Re: Where is my MAP sensor?! JDM B16A and a 93 CX hatch. (Gray EG)
Re: Where is my MAP sensor?! JDM B16A and a 93 CX hatch. (Eg6 ed)
ur stock map is on the firewall
[Modified by There is no sp00n!, 1:59 AM 2/27/2003]
it is mounted to the firewall mid center, about an inch from the top of firewall, it has 1 vaccuum line going from throttle body to sensor and one harness
Re: Where is my MAP sensor?! JDM B16A and a 93 CX hatch. (smokeeater2894)
its supposed to be mounted to the firewall but all i did was connect a hose to the brass nipple on top of the throttle body to the bottom of the map sensor and then i ziptied the map sensor to the firewall.. just do a search this has been covered alot of times with pics to answer all your questions
Jake92eg
15
09-19-2007 05:57 PM
CRXified
35
12-29-2005 07:49 PM
HybridCoupe
10-11-2002 12:16 PM
