Where do these plugs go(dash wiring)
fixing **** behind my dash today, found a few unused plugs
behind gauge cluster, maybe a ground?
this was on the floor behind the center console, below the heater area
any ideas?
UPDATE:
hooked up the heater hoses to the motor, and still no heat, just blows cold air, this is getting frustrating
Modified by Timmay at 1:25 PM 3/31/2005
any ideas?
UPDATE:
the top one looks definetly like a ground of some sort but what?
the bottom one almost looks like the plug for the stereo? and then maybe the cigarette lighter for the small one?
Re: Where do these plugs go(dash wiring) (hybridvteceg)
well does the floor part of the heater have its own wiring? cause i dont get air when i put it on floor
im sure that ground is needed?
Location: Why so you can pretend like youre interested, FL/OK
Re: Where do these plugs go(dash wiring) (Timmay)
Probably easier to let everyone know which ones you do have plugged in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">well does the floor part of the heater have its own wiring? cause i dont get air when i put it on floor
im sure that ground is needed?</TD></TR></TABLE>
Theres going to be wiring going to the blower. Is something not working as it was, like your heater fan?
Re: Where do these plugs go(dash wiring) (f1z1c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1z1c »</TD></TR><TR><TD CLASS="quote">Theres going to be wiring going to the blower. Is something not working as it was, like your heater fan?</TD></TR></TABLE>
well my fan works on defrost, and vents but no floor action
i have no clue where the big plug goes, there is nothing around there for it to plug into
The service connector on Honda's is behind the PS kick panel.
The bottom pic is for the center console.
I just swapped my dash. There is a connector behind the cig lighter console that just plugs in, I am not sure what the wires go to, but that looks like that plug. The little one I think is for the cig lighter and lights around there.
DO I SPY A MAD TYTE RARE JDM SKUNK2 ECU y0?
Re: (Cray91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cray91 »</TD></TR><TR><TD CLASS="quote">The service connector on Honda's is behind the PS kick panel.
DO I SPY A MAD TYTE RARE JDM SKUNK2 ECU y0?</TD></TR></TABLE>
well my cigarette lighter is plugged in, that wire comes from the top harness, my climate control is plugged in, basicly i dont have anyting unplugged that those 2 could plug into
and the ecu is a skunk2 p28
the second one looks like the plug Ive been looking for to hook up my hazards. Do your turn signals work ? Does anyone know where i can find a plug like the second one ?
I am a (Trial User) Army
Didn't read all the other posts but:
1. Ground for the underdash harness. It goes behind your cluster on the right hand side of the steering support.
2. That either goes to the back of the climate control OR it's the other part of the heater harness that plugs from the heater core to the fan blower.
Re: Where do these plugs go(dash wiring) (litterbox)
yea i have the harness hooked up from the climate control
and my fan blows air
hmmm who knows
hmmm who knows
Was your car an auto at one time? The big plug looks like something tat would plug into an automatic mechanism but i could b wrong.
Re: Where do these plugs go(dash wiring) (wickedhatch18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">yea i have the harness hooked up from the climate control
hmmm who knows</TD></TR></TABLE>Does your fan blow heat? It could be the plug that goes from the heater core to the fan blower(in the middle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">no heat, i dont have hoses going to the motor yet</TD></TR></TABLE>What did you use to cork the holes on the engine? I used rubber stoppers and one time driving one blew out and I lost all coolant.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">What did you use to cork the holes on the engine? I used rubber stoppers and one time driving one blew out and I lost all coolant.</TD></TR></TABLE>
hook hose from one side to the other
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">hook hose from one side to the other</TD></TR></TABLE>That's soo simple, yet genius! I shoulda just got hose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">fixing **** behind my dash today, found a few unused plugs
any ideas? </TD></TR></TABLE>
The first one is a ground so put it anywhere. You see on the picture where it is white there should be a tab that is bolted to the steering column support brackets. But if there is not just ground it anywhere
The second one.. first take out your center console... You will see a spot to plug it in where the metal dash support is. Look around may have worked its way under your carpet or something.
