When using the JDM ITR rear trailing arms can...
Re: (dantastic)
I thought you could use EK rear LCA's, ITR rear trailing arms, and EK springs and struts(all on an EK, of course). I don't think the trailing arm effects the springs and struts, rather the lca's. Please correct me if I am wrong.
Re: (96BlackHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96BlackHB »</TD></TR><TR><TD CLASS="quote">I thought you could use EK rear LCA's, ITR rear trailing arms, and EK springs and struts(all on an EK, of course). I don't think the trailing arm effects the springs and struts, rather the lca's. Please correct me if I am wrong.</TD></TR></TABLE>
I believe it's like that also, unless JDM ITR lower control arms require the use of the LCAs too.. I have USDM GSR rear trailing arms and EK LCAs.. and I'm using a shock for EKs.
the way ive always known it to be is that the rear trailing arm wether it's USDM or JDM you can use the stock EK shocks, and the front you cn use either the stock EK upper control arms or the ITR USDM or JDM , BUT you need to keep your stocl LCA on the EK with the ITR hubs wether they are USDM OR JDM , correct me if I'm wrong
thanks sky , you just made me realize what i was confused about , i coudnt picture it but your right the shocks bolt up to the othe part that bolts onto the trailing arm. so basically you do use civic EK shocks and springs regardless of the brake setup .
Re: When using the JDM ITR rear trailing arms can... (SPOONfdEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOONfdEK »</TD></TR><TR><TD CLASS="quote">you still use the regular EK springs and shocks? </TD></TR></TABLE>
Yes you can as long as you use the stock EK rear LCAs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOONfdEK »</TD></TR><TR><TD CLASS="quote">the trailing arms are one thing and the LCA are another right ?</TD></TR></TABLE>
Yes, they are different.
lDanny
13
06-10-2004 02:00 PM
Ehron
10
01-17-2003 05:19 AM
