Wheel Horsepower?
Wheel Horsepower?
I plan on buying an EG.. doing a GS-R swap.. then turbo, then internals, and more psi,.. anyyways, does anyone have a eg with a GS-R turbo, running like lower than 10 psi? if so whats your whp
Thanks
-Cody
Thanks
-Cody
Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">seriously depends on the tuning involved.
stock GSR with 8psi and a decent tune should pull ~250 whp.</TD></TR></TABLE>
agree
agree
Re: (JDM=****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM=**** »</TD></TR><TR><TD CLASS="quote">Size of turbo and the tuner make it vary. </TD></TR></TABLE>
Yeah
For instance, 8psi on a TD05 with a shitty tune is going to have alot less power than a 60-1 with a good tune.
Yeah
umm. not true at all poon. you see if you are running 15psi with a 14b its less efficient than running 15psi with a gt28 or so. a smaller turbo running the same boost as a bigger turbo will always produce more heat therefore the air charge wont be as dense reducing power. i know we are talking under 10psi, but your statement is too vague and could confuse people.
Re: (schardbody)
Here is a website that I have found to show some interesting things. Try http://www.importreview.com, then click on dyno charts. It has alot of info on different cars but it will atleast give you an idea. One of the charts on there showed 230whp for a stock 8psi gsr.
Re: Wheel Horsepower? (dohc-crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohc-crx »</TD></TR><TR><TD CLASS="quote">i have a 300 whp in del sol with stock motor at 7.5- 8 pounds with a full race turbo kit</TD></TR></TABLE>
I call BS. Any dyno sheets?
Re: Wheel Horsepower? (Brodie Bruce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brodie Bruce »</TD></TR><TR><TD CLASS="quote">
I call BS. Any dyno sheets?</TD></TR></TABLE>
300whp is possible..the guy could have a built and ported head with some oversized turbo..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CodyC142 »</TD></TR><TR><TD CLASS="quote">I plan on buying an EG.. doing a GS-R swap.. then turbo, then internals, and more psi,.. anyyways, does anyone have a eg with a GS-R turbo, running like lower than 10 psi? if so whats your whp
Thanks
-Cody</TD></TR></TABLE>
There are so many variables..I suggest looking around at some dyno sheets of setups to get a basic idea..Heres 203 dyno graphs to look at. http://forums.evans-tuning.com...91de8
Thanks
