What's the widest tires I can go with on 99-00 Si wheels?
I am going to get some Si wheels and just wondering if I can put 205's on instead of the normal 185 or 175.....
Will there be a better chance the tires will scrub w/ 205's (dropped around 2.75")?
Also what thickness sidewall would I need to go with?
...or would it be better just to stick with the stock size tires?
Thanks!
Thanks!
Re: What's the widest tires I can go with on 99-00 Si wheels? (LX98Civic)
205's will fit on the Si wheels fine. The stock width is 195/55/15 just for FYI. With that drop you may rub, and you may not. Some people say they rub with 205's, and other don't. I guess it just depends on what tire you purchase. Some are wider than others.
'99-00 Si wheels stock are 195/55/15. tons of people opt for the 205/50/15 when changing tires.
i had '97 gs-rs which have the same dimensions as the si wheels with 205/50/15 and was dropped 3". no rubbing problems ever, but i did tuck my fender linings in... it also depends on the tire though. some have a squarer outer tread than others and as stated above the 205s vary in actual width.
[Modified by WiZeBaNaNa, 3:45 PM 8/20/2002]
Re: What's the widest tires I can go with on 99-00 Si wheels? (WiZeBaNaNa)
205's are cool, mine don't rub either on my 95 gsr's dropped 2 1/2 inches? i dunno, i have coilovers so i have like a finger all around.
what kind of tires are you thinking of getting?
falken azenis
falken azenis
New User
I have SI wheels on my 94 4 door and mine is droped around three inches and they do not rub,i have 205/50/15 on them,they hit my inner fender when i turned really hard, but it doesnt do it anymore because it got worn down enough.
Re: What's the widest tires I can go with on 99-00 Si wheels? (cre18)
Falken Azenis===
Matter of fact...never heard anything bad about em cept for some greasy tire issues or something after hard runs...i think a spray bottle cures this!
[Modified by 95civiccoupe31, 7:01 PM 8/20/2002]
Re: What's the widest tires I can go with on 99-00 Si wheels? (95civiccoupe31)
Thanks for all the info!
At this point I am not sure what size tires I will get. Not even sure about where I am even getting them from.
Anyone got the weight on the Si wheels??
potatostix
35
05-05-2004 07:23 AM
Sipower99
08-19-2003 04:37 PM
