what's the difference?
between the:
p08 ecu
p28 ecu.
i'm running a jdm d15b sohc vtec motor and planning to boost in the future... which 1 of those should i be picking up? appreciate the help... thanks.
p08 ecu
p28 ecu.
Re: what's the difference? (BlueIntegraBoy)
p28 will make your d15b run rich. p08 is better for the d15b. I don't know if the p08 can be socketed and chipped for hondata/uberdata etc if that's what you want to use for engine management.
the reason i want a p08 is only because it is orginally for the engine. so if i was to run the p28 when i boost... no need for a fuel pressure regulator?
AK_CRX
11-08-2007 08:39 PM
