whats the best suspension setup for road race in an EG hatch?
whats the best suspension setup for road race in an EG hatch? i dont want anything too hard ***, or too expensive. basically, whats the best for the money in these things?
later
later
Re: whats the best suspension setup for road race in an EG hatch? (Robster)
Just swap to TYPE R 5 lug and use the stock TYPE R suspension. You will probably be very happy and it is not way too expensive. Plus you get the cool Gunmetal wheels.
Re: whats the best suspension setup for road race in an EG hatch? (twinturbobb)
Koni and Eibach coilover set up. I have a set for sale, real cheap. If you really want a good set up try MOTON with Eibach. I saw a few of the Speedvison Cup cars at Button Willow with that set up, one type R and two Civics. It is very expensive though.
I said I don't want a title!
Cheap way out = Ground Control coilovers with spring rates of your choice and a set of Koni or Tokico shocks (adjustable).
For springs, you need to decide if this is a road car, road/track car or track car only. Spring rates also determine if you'll need to get the shocks revalved. If this is the case, then go with a set of revalved Konis matched to the spring weight.
And don't, I repeat, don't get a set of Neuspeed lowering springs (or something like that) and think they will work well on the track, because they won't.
Re: whats the best suspension setup for road race in an EG hatch? (Todd00)
why wont neuspeeds work on the track? on the race springs the spring rates are pretty high...somewhere in the 400-500lb area...
Re: whats the best suspension setup for road race in an EG hatch? (hydroflip)
I have neuspeed race springs and neuspeed koni yellows it cost me around $700 for this setup. I'm very happy with it.
Re: whats the best suspension setup for road race in an EG hatch? (PhucNguyen57)
why the hell would you use a stock type r setup when you can get better **** at a lower price??? does anyone have any experience with the h&r, tanabe, or tein setup?
later
later
Former Moderator
Stock Type R 5-lug?
RIP OFF
For the $2,200+ that they go for, I can think of better **** to buy.
The struts aren't that great, and the ride height will be higher with the stock Teg springs.
You could get some Konis, Groound Controls and a camber kit for the suspension.
You could also still add a FastBrakes Wilwood 4-pot 11'rotor combo up front and murder Type R equipped Civics in braking distance.
Hell, try adding a GS-R rear disc conversion and the FastBrakes 11.4inch rotor combo with O.E caliper relocators.
All that will ruin the 5-lug equipped Civic's day for the same or less money. I'll break down the prces later, but I'm off to work now
RIP OFF
eg4usdm
Suspension & Brakes
13
01-28-2005 08:40 PM
h22a_ej
10
12-26-2004 09:49 AM
austrian type-R
10-31-2002 01:36 PM
